Surely you meant to create repeated expensive visits?I thought they came as standard equipment in order to cause repeated expensive visits to a dealer workshop ?
Has anyone fitted a Diesel Particulate Filter?
The van he has would not have one originally.OP may mean DIY replacing of an existing DPF.
I’m a dope who doesn’t understand these things. Thanks for your help.Why would you just fit a DPF, even if you managed to fit one after market somehow to your vehicle it would do nothing without all the other stuff to go with it, DPF sensors, ecu to perform regeneration etc etc. Im struggling to understand your original question to be honest ???
This sounds interestingThere are dry dpf kits out there that use a replaceable cartridge rather than regeneration. These could be fitted by any exhaust fabrication garage if you have the space under your van.The temps are much lower than conventional dpf's so less of a hazard.
<Broken link removed>
then the question is, why would you want to? your van can never be LEZ compliant even with one fittedMy Van is a 1991 Tabbert
