bobandjanie
Who turned the lights out??? Jane
dismantle the post.....
look at the wiring to the outlets....
2 or more linked by a common 'live' wire will be on the same phase....
one wire, one outlet...one of three phases to that outlet only.
just run your genny you tight ****....that'll give you 40amps+
you can test to see if the outlets are on the same phase by using a suitable multimeter
although it is most likely that if a post has 3 outlets they will be on separate phases.
Excuse the pun but this thread should have its plug pulled, 415 volts in a tin can is deadly.
Nick
This. Don't do it Bryan. It's just not worth it.
Site EHU supplies are run in three phases + neutral .. one phase per socket .
it would work if both on the same phase but as you don't know this .. it's a big NO .. do not do this
please please do not do this.. this is really bad advice .. having two phases in a van is highly dangerous ..
I wouldn't give medical or legal advice ..if your not qualified please don't give electrical advice..
But from what I've read, that will only happen if two phases are brought in, if two connections are on the same phase then that will be 220v, is that not the case?
Bryan .. why are you persisting with this.... ?
Because on occasion it might be advantageous to be able to double the amps available.
I appreciate that it is not safe to do so if the two connections are different phases, hence MY change of tack on this thread to discuss if it is possible to ascertain whether the two connections are on the same phase or not.
Pappajohns detailed destruction of the shookup post indicates quite well that whilst it CAN be done, the method means it is practically impossible.
However, aba says it can be done with a suitable multimeter and it is this direction I wish to explore further.
I haven’t read much of this post as it is too long so I make my excuses for incompetence before I start but connecting two different phases through one post would be extremely bad engineering practice and something that should be avoided by the circuit designers at all cost.OK.. to ascertain if it's the same phase , with multimeter set to AC volts, test between live pins of sockets .. IF ZERO volts it's same phase...
However .. the danger is that you could read ZERO volts due to a poor connection , duff meter, sockets incorrectly wired.. and draw the wrong conclusion.
Testing for phases should only be undertaken by a qualified electrician , my concern is that discussing on a forum may result in someone trying this and being injured..
Advice given by the unqualified is best ignored ..
PLEASE FORGET THIS IDEA, I AM A TIME SERVED ELECTRICAN AND WOULD NOT CONSIDER DOING THIS.
Nick
Nick.. you and I have both advised to drop this topic .. threads like this can give people ideas ..
Jim ... can this thread be closed before someone is hurt ... better still deleted
Hi Jim if this is aimed at me Rest easy :thumb: let me assure you I am not allowed to touch any leccy in our van other than a fuse which, touch wood I have not had to look at in almost 4 years ONLY CURIOUS AS TO WHAT BRYAN IS HOPING TO ACHIEVE
terry
Better to leave the thread as a warning to others, rather than delete it.
look at it on a smaller scale bryan.....
a 10 amp charger will give you 10amps/hour
a 10 amp (120w in theory) solar panel will give you 10amps/hour
combined, they will charge your battery at 10amps/hour, but will assist each other so run cooler.
put a load of 20amps on the battery and it will discharge at 10 amps/hour,
just the same for 230v....no benefit !
Not sure your correct with this one Jim
Charging at 10 amps is 10 amps no matter what you do or how many 10 amps there are.
2 x 10 amps does not give you 20 amps, it still just gives you 10 amps.
Im sure Newtons 3rd law comes into this somewhere.
my thoughts exactly.....to charge higher you need to supply higher current...not more of the same value.
as you say.....10 amps is 10 amps no matter how many sources it comes from.
rethinking
I was thinking two 10A solar panels in series ... which would give 20A
john is correct with that part of the logic , ie two chargers in parallel still give 10A
but wrong about 2 x 230v ac supplies which will give you double the rated individual amps
I conceded that point john..
but it can't be likened to the 2 x 230v scenario .. the original question asked by Bryan
Bryans query refered to two hookup leads into one 'back to front' hookup splitter, then into the hookup socket.
this connection would also be in parallel so would still be 7amps @ 230v
two AC supplies in parallel will double the available current ,
but I'm not going to argue this point John .. we would be here all night ..
agree to disagree.
