we own niessman and bishcoff arto 69g,drivers and passenger windows have blown anybody know a solution new ones are out of the question,HELP!!!!
I know an aire in Holland where the local youths will do that for fun ... might be difficult to explain how it happens to both sides though and if their aim is cr@p it could be 'interesting'!Someone more devious than me might say the following 3 words in your ears..........
- Brick
- Windscreen
- Insurance
Bit difficult when it's the door windowsSomeone more devious than me might say the following 3 words in your ears..........
- Brick
- Windscreen
- Insurance
It's not a Ford, so you need a brick to get in at the sideBit difficult when it's the door windows
There is an Arto double glazed unit on E bay for £185 not sure how to do the link its under "arto motorhome window " the seller is P & J Leisure
I would be interested to know how that works Jon.Last year I had a conversation with one of the staff at Polch who claimed to know a firm who could do it without removing the windows. I'll try and follow up.
I asked one of the windscreen companies and his advice was to go through the insurance and then pay them full whack to get the units from Germany, I said it wasn't insurance as it was just age related so I suggested I lied to them, well that's not my style.Someone on Carthago Owners had very good service from a company called PSV Glass.
He recommended this contact for efficient service:- nicola.windsor@psvglass.co.uk
Hope it helps.
Richard.
Yes I'm also sceptical, but have emailed them and will report the response. One of my fixed panels has got a small amount.I would be interested to know how that works Jon.
Martin
What do you think causes it Martin?
The same as any other failure on double glazed glass. Sealed units if subject to excess moisture will eventually fail. All double glazed glass will eventually fail, regardless of the quality and how its fitted.
Depends to SOME extent how they have been fitted though and the quality of the unit in the first place, is, the quality of the outer seal.
Is the glass sat on spacers and are drainage apertures fitted and not blocked.
A motorhome gets driven over rough roads, potholes, shaken, stirred, then left sat out in winter storms etc,
They would be better off fitting thick 5mm or 10mm laminated glass, last forever.
DG glass is just a crap selling gimmick in motorhomes, great if you are buying a new van every 3 years(although some even fail in that time), they know some poor bleeder will have to fork out about 2 grand a side down the line for something that they will have paid about 100 quid for. Nice little earner. I mean, come on, with the massive expanse of single glazed glass on A class windscreens, does it make any discernible difference. NO.
Money making racket unless you sort it yourself, as Martin did.
Back to the OP original question, both his driver and passenger side have gone, that's 4 grand down the swanny unless he sorts it himself, he either needs some overtime in at work or cash another pension in.
Me, cynical? Never.
I dont know what you mean by "cut them out" the frames themselves SHOULD be fitted to the van with non setting mastic so you just remove all the screws from the inside and the frame comes away, now if some plonker had refitted the frame with sikoflex or similar adhesive that would involve a bit more work and could be described as "cutting them out".I owned the same vehicle and took it to N&B in Polch Germany, they had to cut out the windows on my 1998 69G because they were a bonded unit. Some funsters say this isn't necessary but I don't think the factory would have cut them out if there was a simpler solution.
The agents in UK Travel world quoted me £3000 per window to supply and fix, Polch were half that price.
Suggest contact Polch and bite the bullet and get it done or sell it and take the hit. Driving with misted windows scared me to death, I could see nothing in my wing mirrors on a rainy or damp humid day.
Hi Paul
Cynical? possibly just a little bit
I am with Jon in thinking that they are an improvement over single glazed side windows cooler/warmer and quieter when you are driving, but yes a PITA when they steam up, to me the big problem is that the dealers don't have a sensible fix to the problem as changing the whole frame and two DG panels when one fails is what makes the "fix" a silly price. I had a conversation with one main dealer in the UK about how they could offer a service to their customers and save them a couple of bob but they were not interested as its easier to change the whole frame (1 hour job) and make the customer pay.
There must be a business opportunity out there for somebody, just not me though.
The latest N+B Arto and Flair have a different design of DG side windows where the second inside glass is stuck to the outside one and does not sit in a frame or channel so the seals should last a lot longer, But they look more difficult to remove if there is a problem as the whole glass panel is bonded to the side of the van. I suppose only time will tell if this is an improvement or not.
Would I have DG in our next van "Oh Yes".
Martin
Bloody hellWell! On the way to the February NEC show, Lyn my wife was driving our camper and I was driving the Van Bitz exhibition unit. A stone flew up and chipped the windscreen on the camper. The chip rapidly went to a crack. The screen should be being replaced, finally in a couple of weeks at a cost of £9,200.00 Our insurance excess is £1000
