Double AGM battery tie down
DethleffGlobetrotter
Started in 2005, then took a 15 year break, back in 2022
Looking at putting a 2nd matching leasure battery in my new Motorhome along with a smart shunt.
I know about cross wiring etc, and will put in a small busbar to make it easier to route the wiring across them.
The electrical area in the garage has a place next to the first battery, but there's no bracket or tie downs.
I'm after a recommendation on tying them both down. I've seen some double trays so could take out the single bracket and just bolt in a double tray, or maybe I could just fit tie down straps for the new battery.
Cheers.
Steve
I ended up making one. Two pieces of 3mm L shaped ali. Driller and bolted, easilly as strong as the original.
