We have an about 8 year old RM7655L fitted, it was replaced in the past under some form of warranty (previous owner), MH was built 12 years ago.
Last trip out the cooling became slightly erratic so decided before driving off to Le Mans in a couple of days time to take a look at the gas flame and electrical connections. Have read some of the threads here with problems others have had and found the fridge drain tube that clears moisture from under the fins in the fridge slightly blocked, just as others have mentioned. Renewed the hose and unblocked the fridge tube.
The first question is about the exhaust pipe exit. Enclosed two photos of the rising pipe where the gas exhaust gases exit, it finishes about 100mm (4") inside the inner side of the upper grill. Have only had older MH's before and thought the exhaust ended in an alloy? tube and housing which exited the gases to the outside of the body. This design (if nothing is missing) exits to the box space behind the fridge/freezer, but there is no way that the space behind the fridge is gas tight to the interior of the MH.
Is that correct or is there something missing?
Second question. It's pretty warm here today and the fridge has had the door open all day. The temp in the fridge was 29 oC when I started a test of the fridge on gas, an hour later it's 28 oC.
The fridge tube and compressor? are just faintly less than warm, not how I expected them to be after an hour. The freezer tube is too hot to touch and the fins just about touchable, about how I would think they should be. Have only one thermometer so don't know what the freezer temp is, but it feels as if it's just on the edge of frosting up.
Should there be such a discrepancy at the rate the fridge and freezer cool down or is there something wrong?
Thanks very much for any help.
