Dometic Power Rail
1ten
Our Globecar has most of the lights fitted to Dometic Power rails. These have LED strip lights powered from them.
We have some Dometic USB chargers that also fit in the rails to charge phones and kindles. Is there any reason that you cant have a light and two USB charges powered from one rail? The circuit the lights are on have a 10 amp fuse, the USB chargers output is 5V 2amps. The LED lights are 1.3W and 3.8W for the longer lights.
I have this question too!
We want to get a couple of the USB accessories to use either on the Dometic power rail above the table (which has a strip light) or on the rail above the bed (which has two 1.5W spots). Is there a limit to how many accessories you can add to one rail?
Thanks.
Possibly the power rating of the track, However if uou connect the other end of the track to 12 v you could double it as you would have a mini 12v ring.
I have operated two of the supplied lights and one usb point from my dometic rail no issues so far.
We have 2 USB chargers and 1 light on the power strips with no problems.
I can't find any power rating for it but the rail should be fine the limiting factor will be the wiring to it. If you load it it with too much you may get a volt drop providing none of the wiring gets warm when fully loaded it will ok.
