Did you take it apart Lenny or just spray through the small holes at the rear of the door?That's correct just on 3 sides.
It smells a bit after spraying with the grease first few times you use it, so I run the oven for at least 30 min on full blast after spraying.
It only needs doing once or twice a year.
Poked the long spout into the slot behind the door and in the slot on the door, then worked the door open & closed a few times.Did you take it apart Lenny or just spray through the small holes at the rear of the door?
There is a small hole on the inside of the door that you can get the spout into as there is a spring and slider mechanism in there.Poked the long spout into the slot behind the door and in the slot on the door, then worked the door open & closed a few times.
