Dometic LS500 vent cover (1 Viewer)
Pk9009
4
McLouis Glen 363
3 years
Does anyone know where I can buy a new vent cover? Mines gone missing! Online search says discontinued. Is there alternatives (do 2 smaller ones fit for example)?
17,630
43,270
the L200 lower covers also fit the L500 in pairs
P
Pk9009
4
McLouis Glen 363
3 years
Thanks. Its marked Out of Stock when you Add to Cart 😔
17,630
43,270
oh, do you mean the actual grill, or the winter covers?
P
Pk9009
4
McLouis Glen 363
3 years
2 x L200 fits? That's excellent
P
Pk9009
4
McLouis Glen 363
3 years
Yeah, the grille. Its gone leaving big hole!
Oct 28, 2021
burstner soalno
Did you buy two L200’s did they fit if so are they called LS200’s we need an L500 but are discontinued? Thanks
pwilmo
344
544
Kings Lynn, Norfolk
Auto Roller 747
You will have to be very lucky to find these large grills, yes they are discontinued and very very rare.
People who advise two smaller covers are mis informed as you need the large grill in place to attach the smaller winter covers.
Your only chance is going to be caravan, motorhome breakers, I speak from experience, having the sama size large vents .. Good Luck
Feb 18, 2019
309
204
East Anglia, UK
N&B Clou Liner 2001
I need winter covers for two fridge vents:
  • Upper: 477 x 370mm (external measurement)
  • Lower: 477 x 183mm
An LS200 would fit the smaller one and it sounds like an LS500 winter cover will fit the larger one?
Does anyone make replacement covers? Or will a pair of LS200 covers work?
Feb 18, 2019
309
204
East Anglia, UK
N&B Clou Liner 2001
Bit more Googling and I found Dometic advise 2 x LS200 as an alternative to the discontinued LS500.
8
82125
thanks for the reminder (to order)!! Im after 2x LS200's myself!
I just need to find a seller that sells just the 200's in pairs (or alone rather than the sets that consist of a smaller vent i cant use)
8
82125
Is this the right one for my dometic 8505???
Its a 300 not the 200 i thought i needed, but the dimensions are correct to cover the entire vent leaving a small gap at the bottom (i only have one vent on my MH)?
Amazon product ASIN B006K1DZB4
Apr 3, 2018
3,660
10,181
1995-2004 & 2017》
Be
Be careful.. there is a LS 300 and a LS 330.. not sure what difference is... but they are very similar.
8
82125
I'm pretty sure the LS300 and LS500 are different sizes, have you checked the dimensions?
the dimensions listed for that LS300 look exactly right when I measured my vent (leaves a few millimetres at the bottom edge)
Really confusing when I understand a dometic 8505 is supposed to need the LS500 or 2x LS200.
Also I only have ONE exterior vent (low down) is there meant to another smaller one higher up?
Nov 8, 2020
638
1,266
Harpenden
Auto Trail Comanche
I
is the upper vent on the roof.
8
82125
I
Ah! so THATS what that white oblong thing is! (on the left) Thanks! :D
Feb 18, 2019
309
204
East Anglia, UK
N&B Clou Liner 2001
From what you say the 2 x LS200 alternative to the LS500 winter cover is the way to go.
According to a retailer, the LS300 winter cover is:
Suitable for vent with overall dimension of 520mm x 280mm.
The LS500 vent is reportedly 371 x 479mm externally.
I don't think you've quoted your dimensions?
Feb 18, 2019
309
204
East Anglia, UK
N&B Clou Liner 2001
Here are two files Dometic sent me this morning which explain winter vent cover sizing.
Vent cover vs the inner edge dimensions of the grill frame (see diagram in Dometic Winter vent guide.pdf):
  • LS100: 371 mm x 130.5 mm
  • LS200: 442.5 mm x 130.5 mm
  • LS230: 353.6 mm x 303.6 mm
  • LS300: 482 mm x 223 mm
  • LS330: 401.5 mm x 223 mm
  • LS500: Use LS200 2 covers per grill
  • Dometic Winter vent guide_Jan19.pdf
  • Dometic Vents 11.1.pdf
sonar
1,267
2,050
I am using a black bin bag as a winter protection cover.
on my fridge side vents.
opened the vents spread the bin liner on the back then refitted it and trimmed off the access.
cost next to nothing…..
8
82125
my post with my dimensions appears to have vanished for some reason? Cant remember what they were now.
But the WA300 is the one that matches what i need (and leaves a small gap at the bottom). I ordered one a couple of days ago, no idea why my post disappeared.
Nov 14, 2023
Hobby
A very useful thread here, thanks everyone for posting their information.
I am also searching for a L500 (LS500) vent (not the winter cover). Like all of you before me, I've found it out of stock everywhere.
Does anyone know of a breakers yard which might have a motorhome of this vintage (early 2000s). Long shot but that's all I'm left with. I'll message the 3D printing guy above but hard to imagine he'd have a way to print one of these. I do have one L500 left on my upper fridge, maybe there's a way to scan that and make a copy?!
Nov 8, 2020
638
1,266
Harpenden
Auto Trail Comanche
Far too big for me to 3D print. Sorry guys.
PaulandChrissy
