- Jul 6, 2009
- 2,765
- 3,592
- Burstner A Class 736
Dometic hob P1/P18430. Smelt gas check pipes etc first. Found coming from kitchen area. Used gas sniffer found this. Bearing in mind only three years old. All connections were tight so used leak spray discovered this really bad leak. Nothing loose nothing hit ??
This pipe should have three small pipe inserts to centralise the pipe seals where it goes to the control valves. No kidding if this had failed overnight I hate to think. Turn the gas off at the bottle less than 3 seconds pipe was empty.
Tried several Dometic agents obviously the pipe cannot be bought on its own or the assembly £266.49 not available. The complete three burner hob is £669 but no longer produced.
any suggestions Please ??
