Dometic Fridge Vent Colour (1 Viewer)
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Our new Morelo is white. There are of course a multitude of whites and looking at the "white " Dometic vent against the "white" Morelo the vent hits you straight away as in the example below.
Has anybody taken one of these to a body shop and had it painted? I am looking for a solution as white on white looks crap!
Michael
Lenny HB
53,224
149,283
On the coast in West Sussex
Hymer B678 DL
Why not spray it yourself with an aerosol results will be quite acetable if done carefully. You can get special plastic paints and plastic bumper paints but the ordinary car paints work well but dont use any primer or undercoat on plastic. Should be able to get an aerosol paint colour matched to the body.
sallylillian
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
I have a mate with a large body shop and with the right colour code or he can measure the colour I am sure that I can get a better match. The concern is the moving latches and if the plastic will hold the paint, so if someone had done it I could get a heads up on issues. Having said that I understand that Dometic do different colours although I cannot find any confirmation, but I have a grey one on my Flair.
Oct 26, 2014
736
1,433
Lincolnshire
Adria Coral Supreme 680st
since 2001
I think black will work well too, cannot look any worse than that white one
Aug 6, 2013
11,949
16,550
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
U-Pol do a plastic primer that works really well. Without it aerosol car paint goes on well but is easily chipped. The primer prevents that from happening.
Riverbankannie
10,490
61,360
Bristol
IH 630 RL PVC
I’ve spray painted our white vent covers black to match the vent frames. Ordinary car paint.
No problems or issues found ............. yet !
Riverbankannie
10,490
61,360
Bristol
IH 630 RL PVC
Thanks, useful, I have seen that black vents are available which may be easier and more durable, if I can get them!
The black vents seem to be available, our van fitted with them, but not the vent covers. We had no covers supplied so I had to buy white ones.
Lenny HB
53,224
149,283
Hymer B678 DL
I think the covers only come in white & grey, we have grey ones on our white vents, they are on there 3 rd van. Bought grey because the 1st van had grey vents but of course being Dometic the vents & the covers are not the same colour grey. Domectic don't only employ idiots for designers who can't even make a fridge that works properly they also employ colour blind ones as well.
389
389
Devon
Carado T339
Our Motorhome only has a real thorough clean once a year - so frankly couldnt see any difference between the covers and the MH due to dirt! Well done you for keeping yours so pristine.
Nov 25, 2014
279
390
Essex
Since 2006
Slightly off topic but it appears to only have 1 vent, as does my Carthago, despite the Dometic manual showing it should have 2. I had the fridge serviced recently and the engineer couldn’t understand how it worked so well and suggested fitting fans. Are all Morelos like this?
Richard
Aug 6, 2013
11,949
16,550
Kendal, Cumbria
since 1999
Richard
There may be a floor vent - my last Hymer was like that.
sallylillian
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Richard
Not sure about your Carthago, but Morelo install a roof vent. Allegedly and indeed logically this creates a better chimney effect. It was a question I asked from the first floor offices of my German dealer, he took me to a window and pointed out the roof vent. Feed back I have had from others is that the solution outperforms the standard venting. Get up some ladders and look on your roof!
Nov 25, 2014
279
390
Essex
Since 2006
Thanks Sallylillian, I’ll check it tomorrow. It would explain why it works so very well.
Richard
Theonlysue
6,104
7,383
Essex
As Executive 50th an
Not long enough!
Why not contrast rather than try to match?
sallylillian
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Richard
A quote from someone on the German forum LinerTreff:-
"The one with the ventilation on the roof we had with our Carthago too. That worked great. This was our first mobile that did not need a fan."
Interesting!
Nov 25, 2014
279
390
Essex
Since 2006
I have checked and the void behind the fridge is indeed vented through the roof along with the oven (in a separate flue) and the SOG.
two
Aug 4, 2011
4,901
4,571
West Midlands
A-Class Fiat
Roof vents are fine, so long as not covered by snow.
If the colour of an outside vent was the only problem on my van, I'd be rather chuffed.
sallylillian
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
If it was snowing the temperature is therefore less than 5c so the fridge would need its vents covered anyway:whistle:
