Dometic Fridge RML 10.4S - Door Fallen Off.
Mikebo
East Devon
Dreamer D68
I'm a Newbie
Are there any Dometic Fridge experts out there? The door to my 3 way Dometic fridge, Model RML 10.4S has fallen off! (to embarrassed to say how!)
The securing hinge pin has come out, and despite a couple of service engineers trying to tap it back into place, and the judicious use of superglue the mend is only temporary. The pin works loose and the door drops slightly, making it difficult to close.
It seems to me that the only proper fix is to replace the metal bracket to which the hinge pins are attached. (There is one left and right because it is a reversible door.) Nowhere can I find a decent schematic diagram of the parts for this particular fridge, nor can I find fitting instructions for the part should I eventually find a bracket.
So does anyone know a Dometic guru who might be able to help me in my quest.
Hopeful TIA.
Some annotated photos which I hope make it clearer.
What about a wall plug in the hole with a bolt threaded in, then cut the top off the bolt to form the 'pin'?
Or some sort of cavity wall anchor stud?
