Yes the flame looks yellow. Shall do it nowCould be crap fallen across the burner. You need a good blue flame, take off the vent and look inside.
You could try sniffing the top vent, any smell will suggest bad flame.
If so, take cover off burner and give a good blow, bicycle pump?
Indeed flat and level at the NEC car park today now sitting car park Stratford upon Avon and no fridge. Worked perfect on EHU for the last week so obviously thermostat working okay. So some thing to do with the gas flame and whatever happens to that. Flame burning blue. No idea what the flame does !!!The other thing to remember is that these fridges are very sensitive to being operated with the vehicle level. Our fridge works fine normally but, when parked on a relative's drive last year, with only a 4-5 degree slope, we got absolutely no refrigeration on gas. Mails electric worked fine, but gas refused to work until we levelled the Moho.
When I was taking loads of temperature readings in my fridge when playing with an internal fan it got a lot colder when set to max.& turn the stat down as they tend to perform far better around halfway.
All sorted last night with the good advice from many above. Got pump out and gave it a blow then turned the thermostat down to half and the fridge kicked in. Wish it was 30* but was sat in wet and wild NEC then Stratford upon avon car parkIf you are in a hot place, 30c+ you should turn DOWN the thermostat to half way, otherwise it can be self defeating and actually interfere with the cooling process.
The flame is what heats up the freezer/fridge, otherwise you can use electric to do the same thing, oddly, it is this heat that produces the cold you want in the fridge.
Grit dust and bits of rust can fall onto the flame, making it yellow but generally interfering with its efficiency. If this happens, an airline or bike pump may be able to remove the offending objects.
