Dometic 8505 fridge interior light
Boardboi
Edinburgh, UK
Van conversion
Hi all,my interior LED fridge light doesn't illuminate with the door open. I fitted a new light assembly & cleaned the electrical connector but still no joy. Any ideas ?
You have to program the circuit board to recognise the reed switch in the door. I don’t have the details with me but google it.
Thanks. I wasn't aware it had a reed switch. I assumed that the microswitch in the light unit was operated by the door locking arm. I will have a Google.
how do you know it isnt coming on when the door is closed ? ....... or if you do get it sorted, how can you tell the light goes off when you close the door ?... :unsure: :unsure: :unsure:
:LOL::LOL::LOL::LOL::LOL::LOL::LOL::LOL:
Put your phone in the fridge on record perhaps.
Still non the wiser. This fridge doesn't have a reed switch. I'm not getting 12v at the light connector. Is there a separate fuse or possibly a bad contact on the PCB ?
No reed switch just a microswitch operated by the SS lever, where the power goes onto the board it's about 10v so I think it's controlled by a processor on the main PCB. I checked it when I was looking for power for my internal fan.
Boardboi If you do not have it ,there is a service manual , including wiring , For the Dometic 8 series fridge in the Manuals for Motorhome stuff section of Resources (in the menu ) that could be useful in checking for the fault and the lights connections.
Still not sorted. The LED light has has a dedicated 12v input. The cable (brown & white) exits the rear of the fridge & connects to the rear PCB. I'm assuming that if I disconnect the wires from the PCB & connect an alternate 12v supply the LED should illuminate unless the wiring is open circuit. Any thoughts ?
