SOLD Dometic 3-Way AES Fridge Freezer RM6505 (1 Viewer)
Parapilot
214
251
Whiston
Hymer S820
6 years
Dometic (Electrolux) 3 way fridge freezer - gas, 12v and mains - with AES (Automatic Energy Selection) model RM6505
Perfect working order and very clean condition. Can be demonstrated prior to removal. No problem keeping everything frozen even when temperature hit 43 degrees in Spain last year !
135 litre capacity. Complete with all shelves etc.
Full specification here: http://www.giordanobenicchi.it/camper/Fridge/Dometic-RM-6505.pdf
P1010912.JPG P1010914.JPG P1010916.JPG P1010917.JPG P1010911.JPG P1010919.JPG
Feb 4, 2016
2,784
2,128
West Sussex, UK
Hymer B680 Starline
Long term a few years now.
A good fridge freezer ive got an older version in my van and its as good if not better than the one i had in my house.
Jun 17, 2012
2,930
9,907
North Essex
Autotrail Delaware
>12 but <13
I would buy if I could find a way to get my existing fridge out of my Burstner Elegance. None of the dorrs are wide enough!
They are! Had to remove my F/F, oh dear, F/F 1" wider than hab. door, but brainwave, lay passenger seat down and out through huge hole:sneaky:
Parapilot
Parapilot
214
251
Whiston
Hymer S820
6 years
Thanks for the interest.
It's a great fridge, but I am going full time from summer and was offered a larger 190 litre RMD8555 which I thought might be nice (on a whim) ..... :whistle:
Also, I have 400w of solar so wanted to make use of the excess power. The 8 series has a solar input. Now it appears the 6 series also has one - doh !
It will just fit in the recess with a little modification (literally mm precision).
Not sure it was the right decision as the 6 series seem ultra reliable while the 7 and 8 series seem to have a lot of issues with faulty circuit boards (according to forums).
Both sizes are too big to pass through the hab door, but easily fit through the lounge window, and not heavy with 2 people.
Thought I'd put it on here before eBay. £400 ono ?
Minxy
32,624
66,459
E Yorks
Carthago Compactline
Oh how I wish that would fit in my camper! :crying:
2657
I had that problem with our last Hymer caravan. Managed to get the fridge out of it's space, which wasn't easy, and then had to remove the working parts off the back to get it through the door, I think they must have built the van round it!
Oct 29, 2008
5,058
5,911
West Yorkshire
PVC
since 2008
I miss the AES mine is manual. I would change it if it was an easy job but I dont think it is? Even though mine is the slim version
Minxy
32,624
66,459
E Yorks
... if you do I'd be very interested in buying your manual fridge freezer for my camper as it should fit! :) (y)
Go on ... you KNOW you want AES ... :D2
Oct 29, 2008
5,058
5,911
West Yorkshire
PVC
since 2008
Find me one and I will consider it, The tall slim ones are very rare. Mine is the only one Ive seen outside the USA
makems
3,438
27,692
Ingleby Barwick,,Teesside
Sadly had to give up
Unfortunately I have already measured the driver and passenger doors andthey are also too narrow, grrrr.
I even thought of taking out through the rear bedroom window which is big enough. Unfortunately the door from the kitchen area into the bedroom is too narrow!
Parapilot
Parapilot
214
251
Whiston
Hymer S820
6 years
Careful now - fridge envy could get expensive ..... but the AES is brilliant and couldn't live without it !
I'm too forgetful to manually switch every time, and no worries if the EHU trips or goes off while you are out, or having to switch to gas when you park up ... etc, etc. :rolleyes:
So far, fitting has been surprisingly easy considering the lack of kitchen space, and the fridge passes through the window no problem.
It's given me a good opportunity to reseal the airtight cabinet where the seals had aged, clean out the dust and dirt, and line it with foil bubble wrap and aluminum tape. The additional insulation can only help. o_O
Minxy
32,624
66,459
E Yorks
Tell me what model you have then so I can find a replacement! :D
Oct 29, 2008
5,058
5,911
West Yorkshire
PVC
since 2008
I have the RML9330 Its a great fridge, both size and performance wise. I would need an RML 9335. But can't see them anywhere.
Minxy
32,624
66,459
E Yorks
Unfortunately I have already measured the driver and passenger doors and they are also too narrow, grrrr.
How big is your fridge! Would it come out via the doors if the seats were removed?
... as a last resort ... through the Heki???? :D
Gellyneck
9,195
18,144
Scotland
More than toes wet now!
Had that problem with our RMD8555. Thank heavens was still under warranty (just)!
But you need to watch if you stop for a length of time for fuel that the gas doesn't start to kick in.
makems
3,438
27,692
Its not the size of the fridge thats the problem - its size of the doors!
And the Heki is too small as well :(
Minxy
32,624
66,459
E Yorks
What fridge have you got?
movan
21,492
120,753
Moving around
Burstner
since07
Aside: love your avatar
Parapilot
Parapilot
214
251
Whiston
Hymer S820
6 years
Looks like the fridge will soon have a long journey to a new home in Bulgaria ! (y)
Just wish I was going with it to escape the weather ..... :(
Minxy
32,624
66,459
E Yorks
Jez ... still wanting an AES one ... ?
Northernraider
27,380
176,910
On the sofa ....
Mobilvetta eurayacht
On and off since 95
I always thought the built the inside of the van before the fitted the wall panels
