Dometec fridge/freezer
Buntingford
Adria Coral Platinum
Since 2019
Hi everyone.
The above unit has just been prounced as “dead” in my 2003 Autotrail Chieftain. Has anyone any ideas on where to get a good deal on a replacement? I might even consider a second hand one, perhaps from a write off.
Best wishes, Peter
Have you tried it on gas,and, electric , could be pilot jet if gas or the heater element on electric
This chart might help if you can't get a direct replacement.
Also interesting to see how long before your van was made production stopped on certain models. 5 years in our case!
Broken Link Removed
I was in Magnum’s in Grimsby a month or so back...
Noticed they had lots of heavily discounted fridges and fridge freezers..
Might be worth a call..
An opportunity to ditch gas and go for a compressor instead?
Fridge/freezer was inspected by a certified engineer. Not working on any of the three choices of power supply. Cooling unit shot and no spares now available.
Compressor not really an option as I will not always have electric hook-up! The
Don’t necessarily need hookup if battery/solar/alternator etc. sufficient,
Amazing how efficient these things are worth a serious look into
check the width of your existing fridge, I nearly made an expensive mistake changing ours thought I had found a bargain, turns out one MH manufacturer fits slightly narrower fridges
cant remember the details now, but do recall thinking the price was too good to be true o_O
unless very cheap I don't think I would consider a used fridge, it will have been removed for a reason
good luck with finding one, I presume you had already got a rough idea of just how expensive they were going to be :(
Reading the Globecar thread I got the feeling that compressor fridges are very power hungry. You need some serious batteries to keep these fridges running.
