Domestic freshjet 2200 moved (1 Viewer)
Twos company
215
179
Boroughbridge
VW transporter
Hi my air con in my van doesn’t seem to work very well. When I start it up it seems ok then after a short while approx 15 mins it runs warm instead of cold any ideas please I’ve removed the cover inside and cleaned it out so I know it isn’t that
Duffie
Jan 19, 2014
9,368
24,705
Derbyshire
Elddis Accordo 105
since 2014
Check the fan and heat exchanger on the roof. The fins should be clear to see through and the fan should be blowing warm air out.
Feb 18, 2022
146
146
Suffolk, UK
Rapido 9048DF 2016
Shouldn’t need re-gassing as they “should” be hermetically sealed for life.
If it needs, re-charging with refrigerant. It’s for a reason, that is a leak that needs to be repaired.
Maybe your compressor is drawing high current ?
Agree that it shouldn't.
However a coolant leak could explain the symptoms.
Worth having it checked to eliminate this.
