Does Anyone Know...........?? (2 Viewers)
Tincataylor
639
1,360
Devon
Never leave a campsite with your clothes line tied to a lamp post.
We have an Autosleeper 2007 Nuevo on a Boxer chassis. Both front and rear sidelights have stopped working on the nearside although the bulbs look perfect. I've gone through both the Autosleeper and the Peugeot handbooks for the location of the fuse. I can find a reference to every single bit of electrical equipment on the vehicle EXCEPT the sidelights. Anyone got any ideas...???
TRhe Tincas
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
test bulb holder for voltagewith multimeter may be bad earth would of thought fuse would take out all sidelights
Theonlysue
6,104
7,383
Essex
As Executive 50th an
Not long enough!
There is an autosleeper group on facebook. Very helpful.
ambulancekidd
Sep 23, 2014
10,366
28,389
Ayrshire Scotland
Swift Kon-Tiki 640
Since 1964 Gosh that makes me feel old.
Vehicle fuses have redundancy built in, this ensure that a vehicle doesn't suffer complete failure of sidelights or headlights, therefore the sidelights would be extremely unlikely to all go out at once & as the op says one side has failed.
So it really does sound like a fuse has gone.
Can't help with location of fuse though.
kelpie
563
420
Glasgow
Bessacarr E745
3 years
Another vote with ambulancekid , fuses are normally sided , so one side going suggests a fuse. My van is on a Ducato chassis and a fuse box sits at front of engine. There will probably be another some where, but I'll find that when I need it. There might be a fusebox at one side of the dash, or behind the glovebox if you have one.
Hope you find the box/ boxes, let us know.
John
Jun 30, 2010
7,924
27,229
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
I have on our K reg A/Sleeper a switch on the dash that if operated turns off the N/S "parkers" and leaves the O/S on.
Tiz for parking on the roadside at night, perhaps you have the same
Tiz in the middle of the dash and is the same as the Rear Fog light in appearance.
Gellyneck
9,235
18,208
Scotland
More than toes wet now!
If you have the optional fusebox at the bottom of the right hand door pillar try F58. According to the Fiat Ducato handbook it's a 10A fuse that protects the sidelights. Might be same for for Peugeot Boxer?
Tincataylor
Tincataylor
639
1,360
Devon
Yes, the bulb warning light is on.
Feb 15, 2014
713
1,249
cambridgeshire
Bessacar E450
3 years
if you can disconnect the battery easily do it for a couple of minutes and after reconnecting see if the warning light is off then get someone to watch lights while you turn on and see if they momentarily come on before the warning light comes on.as it is probably the canbus system turning that side off
Theonlysue
6,104
7,383
Essex
Not long enough!
Theres an autosleeper owners group on facebook.
Tincataylor
Tincataylor
639
1,360
Devon
Sue,
We wouldn't belong to any owners group who would have us as members..........
The Tincas
Tincataylor
Tincataylor
639
1,360
Devon
Chatteris,
I think you win the star prize as is the bloody Canbus thingy (whatever that is) that has been confusing the issue. As far as I can tell the reason we could not find the sidelight fuses is quite simply because there 'aint any. By removing the O/S/R light cluster the O/S/F sidelight started working. Someone then kindly tested the (brand new) Stop / Tail bulb and found it was shorting out between the filaments and therefore showing the sidelight circuit an overload. A new bulb has done the trick. Many thanks to all the Funsters who have tried to help,
The Tincas
