Does anyone know how to remove this panel with mirror on, it’s a Fiat travel van
Hornett
fiat travel van
Does anyone know how to remove the panel behind the tap in the bathroom, in a Fiat travel van kind regard
hi welcome.
but sorry cant help it looks a big job, it looks like the tap needs to be replaced can it be diassembled from the fron? Unscrew the round lever and you may get access to remove the top then go from there.
good luck
Reactions: f6c
i just looked up the tap and as you may already know it is fixed from underneath so you may have to remove the panel, unless there is an access panel under the tap shelf.
Or, I notice that the panel preceding the tap panel seems to have cut outs up one edge, possibly for screws.
Wondering if you have to remove that panel, or loosen it to be able to “peel it back” gently, to allow access possibly down the side of the panel with the tap.
Just a thought, but if you try, please be very careful bending plastic panels as they seem to be all-in-one composite units.
Thankyou we did think so looks like a big job☹️
:welcome4: Just done a quick search and Stealaway Alex had to remove his bathroom wall on a Burstner 😯 I'm sure there are probably others that have had problems with this very tidy design in Burstner bathrooms. 🙄 maz 🤔 Bob.
