stcyr
- Apr 11, 2011
- 1,765
- 1,160
- A class
- On & off, since 1966 - fulltime since 2005
Hoping some knowledgeable person can help! I urgently need to find out if the mark 1 Sevel vans - C25,J5 & Ducato - have the same differential.
All three come off the same production line but the Fiat engine is different to the Peugeot & Citroen variants and the gearbox is 'different' according to Fiat. Logically one would assume that the 'difference' must concern the bellhousing.
Surely a large manufacturer run by accountants would not produce two different differentials for what is 99% the same vehicle.
I'm aware that gearbox/diff ref.numbers can be checked & compared, but am not in a position to do this - the box on the vehicle only has numbers on the casting which apparently are just that - casting numbers. The little tin plate which apparently should be on the gearbox, is no longer.
The situation is that I've located a gearbox/diff in a breakers yard nearby, on a Mk.1 J5, but can't afford to buy it on the offchance, only to find the diff isn't interchangeable!
And the van is currently filling a large space in the local garage.
Like most garages these days, they only work on part numbers, which is useless because these parts are no longer made, so part numbers are irrelevant.
Despite days of research on the internet I can't find the relevant specs.of each diff.to be able to compare them.
Someone recommended JKTowers - his website states clearly he doesn't give a phone number or give out technical information ... Another recommended No1 Gear (M.Chubb) who deals in parts for old Sevels - I emailed him but await a reply...
I'm between a rock & a hard place at the mo. ... Facts are: all three badge variants are the same apart from the badges & minor trim details. Most mechanical parts are interchangeable apart from the Fiat which has a completely different engine... So there would seem to be no reason for them to go to the expense of designing a diff. for just one of the three.
Does anyone know for a fact if the diffs are interchangeable?
Thanks, in hopeful anticipation!
