Whats up can't keep waking people up with the electric version, too quiet?We paid to have the soft close feature of the side door on our Globecar Campscout removed. It was a pain in the bum.
It seems a bit silly that if a boiler dump valve opens in freezing weather the pump will run to try and refill the boiler and will empty the fresh water tank.
Surely if the dump valve opens it should shut the boiler inlet pipe at the same time, or override the sensor.
I have one of these unmotorised sliding doors on my van. If you slam it closed with the handle it makes an almighty noise and yeah would wake the devil up. Now if you pull it to within six inches of the closed position and then push it at the rear to finish closing it they are no noisier than your neighbours motorhome habitation door. Like you I cannot see why the previous post would have had the motor taken off though.
Sure do know something!! Have also fitted a grab handle to the rear of the door inside, it works the same and is quiet when closing. I hate noisy neighboursThats if you are closing the door from the outside,but if you are inside you have to slam it,unless you know something i don't ,
There is a fix for that by entering a set of numbers.This can be found on the internet
If your radio is the same as the one in the picture, just check the 180 minute delay and it will stay on for 3 hours.Any idea where?
I've search high and low my friend, I can't find a thing
My radio is the same as this one:
Acknowledging that indicators exist is the first step on your road to salvation. Praise be to God.
Neil I agree with you about the oven, but not the grill. It browned the top of the large lasagne I made very nicely indeed. Granted it is useless at toast, just warms the bread. But you have to understand that it is a European oven and they are only just beginning to understand sliced bread, so they are nowhere near understanding toast yet.
I don't have enough hair left to pull any more out
Thanks for the advice @fairford rambler , I shall abandon my quest for a fix before I drive myself slightly insane looking for a solution that doesn't exist
