ronidog1
... Carry the jack and tools for wheel changing in a motorhome?. I have no intention to attempt a wheel change I would always call Aa or equivalent.
Dave
Dave
Thats interesting, do you know which ones off hand. I wouldn't want to come unstuck and am just thinking of renewing.Some breakdown companies insist you have the tools to change a wheel otherwise you are not covered, look in the small print. If your vehicle does not come with a spare from new, then this does not apply.
the fiat jack is useless, but the kit includes the towing eye and spare wheel lowering tool if fitted so you need to carry those
Agreed. Got home from picking up new van and found I had a screw in the fos tyre. Jack worked perfectly. Used an extended wheel brace to get wheel nuts off. No probs. MikeI found the fiat scissor jack very good, locates securely, does not need massive effort to lift, not as stable as a trolley jack but as good as the 8 ton hydraulic jack that I also carry.
Wouldn't like to undo the wheel nuts with the supplied equipment though.
