ShaKen
Hi all - I’ve a 2018 Model Transit and just getting around to the issue of stopping all the rainwater pouring into the engine bay when it’s wet out!
Water currently enters the engine bay on both offside and nearside ends of the windscreen drainage channels (is it called a skuttle?).
I’ve also noted that water also enters at 2 other points a 1/3rd of the way along on both sides, running down a bracket below the skuttle.
A couple of pics to illustrate...
Water “damage” from running in from drainage channel below windscreen.
Water running down bracket below windscreen, dripping onto gearbox (general area).
Water lying on the engine / gearbox and pooling in the holes of the assembly.
Nearside draining “channel” - which clearly doesn’t do its job as water then runs down into the engine bay via holes in the panels.
So..... what can be done??
I think I can use some hose / plastic / sealant to improve the channels at each ends to ensure no water is diverted into the engine bay at the sides; but what can be done with the sealing the 2 brackets sitting approx 1/3rd in on each side?
Has anyone remedied them?
Of course, perhaps the thing I should be doing is making a formal complaint to Ford and get them to fix it (the van was registered on 2019 and this has plenty of warranty left on it.
Any thoughts?
Any thoughts?
