Yes you can download the full manual (as well as the one for your Elektroblock) from the Schaudt website - they're all in English as well as German, French etc. https://www.schaudt.gmbh/de/service-support/downloads.phpIs this from the Schaudt manual?
I plugged in last night and this morning the panel is back on and showing the leisure battery as fully charged. However, the panel only works when 12V is switched on and I can't remember if this is right - ie. the fresh water and waste tank gauges only display if 12V is switched on. Is this right? I thought they used to display when 12V was turned off. Maybe it was always like that.Dunno! My next thoughts would be that if the panel turns the 12v on and off then the connection between it and the EBL must be OK.
So... Its just the display.
Is there a fuse on the EBL that feeds the display? Does the EBL manual show a powere feed to the display? If not, where does the display get is power from??
Section 4.2 of the EBL manual NB this from the mod 102 manual)
If an overload or an insufficiently charged leisure area battery causes the
voltage to fall so low that the automatic disconnector is triggered, any nonessential consumers should be switched off.
If need be, the 12V supply can begin operation for a short time. In this case
the 12 V main switch on the DT ... control and switch panel must be switched on.
However, if the battery voltage remains below 11.0 V, the 12 V power supply
can not be turned back on.
Fully charge the leisure area battery as soon as possible. For more information, refer to the ”Battery voltages” interpretation in the associated DT/LT ...
control and switch panel instruction manual.
Yes. The panel only works when the 12v button is on. Sounds like it's now all sorted.However, the panel only works when 12V is switched on and I can't remember if this is right - ie. the fresh water and waste tank gauges only display if 12V is switched on. Is this right?
