Brakers
Hi Everybody
As some of you know I have an Autotrail Cheyenne 840D. I have a bank of 4 batteries of 135Amp hours each. If you know anything about Autotrail it is supplied with two harnesses in the battery compartment one for the first battery and another so you can connect a second battery which I have done.
The other two batteries are in the next locker to the rear of the vehicle, all batteries are connected in parallel with as mentioned the first two batteries connected to the vehicle charging system. Yes I know this is not ideal but it is how it is at the moment.
Last year I had two larger solar panels fitted with a Victron mttp charge controller these span all 4 batteries, also connected is a dc3kit to allow the air conditioner to run when travelling and also to give me 240 volts to power some items.
What I want to do is remove each battery in turn and bench charge them.
What precautions do I have to observe if any when disconnecting a Victron mttp controller and which end is it best to disconnect it, battery or mttp controller itself.
I have no problems disconnecting batteries on cars etc but with solar panels it might be a bit different.
Any advice is more than welcomed.
Many Thanks Tony.
Many Thanks Tony.
