Can someone give me info on diesel heaters please the only ones I know of are space heaters and I don’t think they are what is meant
If it didnt come with a mounting Turet plate, it might be a good idea to get one, makes a much neater, safer job if you are venting through the floor as many do.This is what the £90 Chinese heater has in the boxView attachment 585510
The turret is in there although it's the rectangular plateIf it didnt come with a mounting Turet plate, it might be a good idea to get one, makes a much neater, safer job if you are venting through the floor as many do.
LES
Here's a link to show one, but there are many suppliers, this is just one example.
Stainless steel turret mounting plate for AUTOTERM, Eberspacher, Webasto, Planar
What fitting plate do i need? YouTube video hereMade for Autoterm, Webasto, Planar, Eberspacher, and Chinese diesel heaters. Floor mounting bracket will let you to easily install Autoterm, PLANAR 2D air heater in the floor, thus saving more space in motorhomes, caravans, boats or on the...planarheaters.co.uk
That's just a mounting plate which is only suitable for mounting to a metal floor, a turret is similar but has a piece of 150mm steel pipe welded to it to go through the sandwich floor of a motorhome, various lengths are available to suit the thickness of the floor.The turret is in there although it's the rectangular plate
with holes in it middle top
Have a look at the John McKay videos on YouTube and you will be an expert in no time, he is the diesel heater guruCan someone give me info on diesel heaters please the only ones I know of are space heaters and I don’t think they are what is meant
Ah yes I see it now, top middle of picture, not the same shape, but it will do the job, Specsavers are closed on Sunday nights arn't they?The turret is in there although it's the rectangular plate
Unless a new model has been released recently there are actually only two different ones, a 2kw and a 5kw, they have slightly different sized casings. Some of the 5kw ones are advertised as 8kwAh yes I see it now, top middle of picture, not the same shape, but it will do the job, Specsavers are closed on Sunday nights arn't they?
How many KWS is the one pictured please? I know they go up to 8KW and dont use that much more fuel, but that may well be over the top for a normal sized MH, maybe better in a workshop.
LES
Maybe best to explain that it's upside down in the photoThis is a turret for mounting diesel heaters on MH floors.
<Broken link removed>
It depends on the size of your van. They don't work on a thermostat so in a small van like a Volkswagen camper 2kw would be ample but in a bigger coach-built then a 5kw would make more sense
Do you have a Chinese one? I didn't think they were thermostatic unless you bought the aftermarket controller. Even then they must be battery hungry if they cycle off and on and use the glow plug each time?Yes they do, the thermostat is in the base of the LCD controller.
Noooooo, it's disappeared now
5Kw it will be then, if we can still use the van in future years.It depends on the size of your van. They don't work on a thermostat so in a small van like a Volkswagen camper 2kw would be ample but in a bigger coach-built then a 5kw would make more sense
Can the hot air ducting be connected into the Truma ducting ?
Every day is a school dayI have 4 Chinese diesel heaters, 2 of which are on Afterburner controllers and the other 2 on standard Chinese LCD controllers.
The thermostat on standard Chinese LCD controllers is the little bulb protruding from the casing that I have arrowed.
That's my intention, I bought a variable Y valve so that I can switch from truma to diesel heater. I should say that I bought everything two years ago but because of winter Covid restrictions I've not yet got around to fitting anything.Can the hot air ducting be connected into the Truma ducting ?
