Diesel heater problem (1 Viewer)
octopush
147
54
portsmouth
2days
Can anyone help.
I have a diesel heater problem.
I switched the heating on in my motor home the other day to see if it worked and it did for about 5 minuets lots of heat, Then the van filled with smoke from all the open outlets so i switched it off and now nothing at all happens when switch on.
I have not had a look to see what has gone wrong yet but will do later this week.
I was wondering if anyone else has had this happen and could give me a clue as to were to start looking.
Thanks Rob
18,009
48,006
Sounds serious, I wouldn't have thought there is any way the combustion side should be able to reach the blown air side. What type of heater is it?
octopush
octopush
147
54
portsmouth
2days
I was thinking the same.
I think it is a Webasto i will have a look when i get home
18,009
48,006
Webasto have quite a good technical support line. I have heard of people being talked through problems by them, resetting fault codes etc. If it is a Webasto give them a ring.
Nov 30, 2009
6,545
148,889
Pickering
PVC the PUG
When we first got our MH , we were away in it and the normally quiet Webasto ( unless on start up :RollEyes:) started making a right racket. Compared to normal . The Motorhome hadn't been used for quite a long time. Before we bought it.
We turned it off , worried. It wasn't that cold anyway. We were just trying it out. Anyway after a trip back to the dealer on our return , it turns out it was only the self cleaning system thingumyjigs . It does it every once in a while to self service it or something like that...
There was never any smoke though.
lee52
327
119
tyne and wear
selfbuild
newbie
was the smoke diesel smoke? I had one pumping smoke out off the outlets there was (well I think) a nest in the outlet of the heater up against the combustion chamber and once it got to full temp it started burning the nest . has it been unused for a long time
