Didital read out
Fiat ducato
Hi all, I'm after some advice,this digital vault reading has stop working and not sure why, it was working when I hooked up but brought a small blow air heater, tried it out so not sure if it blew a fuse, not to sure what the read out is for any way. foto uploaded.
Do the two sockets work?.
Chances are it's all combined for power and the digital display has failed....unless nothing works then it's a fuse or connection fault
The display shows current voltage at whichever battery it's all connected to.
If you plugged the heater into one of the sockets it almost certain it blew the fuse.
Thanks for the info, plugged my charger into the socket to see if it works but no it doesn't, so its probably a fuse, any idea were the fuse might be, sorry all this is still quite new to me hence the name,
Our van has got a row of blade fuses in the distribution panel under the MCBs I suppose all vans differ though, but look for something similar 👍
Cheers, their is a bank of 6 fuses for habitation, behind the passenger seat that I can see, theirs
its not original equipment so probably has an in-line fuse somewhere under the dash
You'll have to follow the 12v wires back to either the fuse or source (if it was fitted to the fuse board)
