Dethleffs Trend cab rainwater
kenhaus
Wimborne Dorset
low profile coachbuilt
5 years. several more as a caravanner
Have a 2019 Dethleffs Trend on a coachbuilt. Anyone solved the problem of rainwater cascading off the roof and causing it to run down over both driver/passenger doors? Get a full soaking if opening window or door. When used with silver screen tends to funnel through door seal and drip inside door. Have already overcome the poor rain design on the rear where it does ‘Chinese water torture’ by dripping onto the protruding rear ledge that is part of the number plate/ rear light cluster. This was done by attaching by suckers 4 pieces of foam cut to shape. These are attached before bedtime if a risk of rain. (or if you forget and are noise sensitive like me but have 2 single bed designs, I do a 180 turn and sleep with head away from rear of van….equally a good solution to sit with tea in bed in morning to avoid rear cupboards!)
Ha! Great description of both!! No-one has solved both annoyances, Ken and it is much worse in the twin bed T7057EB than in the Island bed DBM, where it is muffled by the wardrobes. Cab waterfall ! Added extra?? 🤭
The only advice I can give (tongue in cheek) is to tour warm countries! 🤭 Great vans, shame about the cab roofline as that punk band might have said?
