- May 11, 2019
- 65
- 511
- Autotrail Savanna
- I’m a newbie
Has any one had any experience of using an electric dehumidifier in their motorhome when not in use preferably one with continuous drainage.
We have found the same . The dehumidifier fills up very quickly when it’s wet outside due to the drop out vents . At first I was pleased and thought I was doing a good job removing all the moisture from the motorhome . The reality was as you say , “ trying to dry the whole world “We use one, not hugely efficient and expect to see a lot of water in the tank. The problem is there are so many permanent vents that you are trying to dry the whole world. May be worth looking round at the various openings, fridge vents, front door vents etc. Best not to close off the gas drop out vents as you may forget to remove it.
As well as drawing in damp air through vents and into van so it can then also dry that out as well ....and over and over.trying to dry the whole world “
If you store under cover then ventilation definitely is your friend.Thanks all for changing my thoughts on the subject as I store the van undercover I shall try ventilation prehaps leaving skylight open a bit?
Waste of time.BUSBY.Has any one had any experience of using an electric dehumidifier in their motorhome when not in use preferably one with continuous drainage.
You shouldn't need to use one but if the interior and upholstery has got a bit damp after a typical UK holiday then it will be a more energy efficient way of drying it out than turning the heating on.Has any one had any experience of using an electric dehumidifier in their motorhome when not in use preferably one with continuous drainage.
I beg to disagree with the majority of the comments above. We always used a dehumidifier on our yacht, you don't get a sterner test than that! Without the dehumidifier, the varnish would get damp and tacky and the cushions would get damp. With the dehumidifier on, everything was dry to the touch. there was plenty of permanent ventilation as well. I can report that the sea didn't dry up. So we have always used one in the van and as Landy Andy says they circulate the air and provide a certain amount of warmth. We also drain directly into the shower tray.
Warm dry air won’t cause condensation! That’s the whole idea of a dehumidifierIt that works for you then fine, though our experience from owning sailing yachts for over 35 yrs was to remove all soft furnishing, open all cupboards and all was fine over winter, we had a keel stepped mast so rain water would find it's way into the bilges, auto pumps dealt with that.
Simple physics tells us any warm air touching a cold surface equals condensation so the addition of any warmth will just make things worse.
A flow of fresh is the proven way to keep mould from forming.
.................If any open vents are only in the roof forget the "drying out the world" myth. Dry air is denser than moist air so the transfer of moisture from outside will be negligible...........
So then the dehumidifier won't work, its all relative to how much moisture the warm air is carrying and how cold the surfaces are, but it's a fact that warm air will hold more moisture than cold air, if the air and the surface are the same temperature there will be no condensation.Warm dry air won’t cause condensation! That’s the whole idea of a dehumidifier
Hi sorry to disagree againWarm air touching a cold surface will most certainly cause condensation that's physics.
In a previous existence we owned a 28' sailing boat (basically a caravan that you don't need a ferry to get you across the channel). For years we used to load it up with those dehumidifiers that you have to keep emptying the water out of and keep filling with crystals - it took at least four dotted around strategically plus another two or three of those bags full of clay that you put in the oven once they get saturated to dry them out again. With all this in place we just about kept on top of the condensation problem, provided we stripped out the upholstery etc..Well... I was going to ask the exact same question, "is there any benefit to putting dehumidifiers in the motorhome whilst its stood up over winter" but then thought to myself, before I start a new thread, lets put "Dehumidifier" in the search bar, and see what it brings up, and guess what, it brought up all of this.
However, after reading all the contributors opinions, experiences and advice, I feel like I'm no further forward. Do I just crack open the 3 roof vents for a few hours when the weather is dry, or scatter a few disposable dehumidifiers about the MH.
I used to put half a dozen disposable ones in the caravan when we had one, and did the same last winter with the MH, the only thing I found in the MH was I needed to replenish the pellets and empty the water collector every 2-3 weeks.
Is it just a case of personal preference, or (as 1 or 2 above have said) dehumidifiers can actually cause damage , if so would I be correct in thinking it's probably best not to take the chance with dehumidifiers and just to open the vents every now and then.
We empty and leave all cupboards open, and remove bedding, but not the cushions.
Who would think owning a MH would pose so many questions, or is it we've got nothing better to do than look for jobs and something to do.
