What about an all electric 12v fridge?
I would have thought more efficient?
Solar panel at the mo looks adequate to me ???
Are you mostly going to be using the van in Spain?
Re the 240v fridge, we've run our domestic fridge via 430w solar and 270amp batteries quite happily over the last 8months, obviously plenty of sun for the charging throughout mainland Europe but we've been back in the UK for a couple of months now and with the lack of sun the batteries are running lower than I'd actually like, 12.4v is the lowest I've seen. That's just purely charging through the solar, no engine charge or hookup charger.
I really wanted to use a domestic fridge as couldn't justify the cost of 12v/3way fridges. Think we spent less on the whole setup than we would have done just buying a fridge and if it doesn't work out will still be using the rest of the system.
Keep the photos coming.
Shawn
Ps if your in the uk and need an extra pair of hands and have a nice bit of land we can park up for a while, I'm your man. Well man,woman and dog lol.
Are you using upvc sheet cladding in the shower room? Will look very smart and proper water proof too.
Hi Daz, look what a coffee morning has done for you. Have you thought about using Lithium batteries, both for size and durability, I believe battery megastore are doing a deal on them
what did you bond the sound insulating foam on with? If it's the self adhesive stuff, I have known the glue to fail if it gets hot. Above the engine it will. I would staple some reflective foil on the bottom too
I went for saniclad in 2mm.Aye, just pricing it as we type.
Cladding monkey! Have 8 x 4 sheets of 5mm pvc for about £16 so works out very reasonable, just looking for a weight?
Ironically it was the driest room, (and I would like to keep it that way) but it helped the leaky rooflight being over the shower tray!
You know what Dazzlin , I absolutely love the layout of your van.. And by the time you are done its gonna be a total cracker !
Dazzlin why not put a temporary bypass onthe switch to prove the electrics before replacing the switch.
think your having a bad day, removed rotten wood from front skylight, and bloody roof cracked, not good fibreglassing in the rain,
It was supported, it was when I removed the rotten left spar, some joker had screwed it to the glass and i missed the screws now running my own thread in self builds,sorry to be a bit late with advice Al-Di but ALWAYS support the roof before removing anything structural like a rooflight surround
with older vans you have to plan for the unexpected like that. When you start rebuilding, see if you can source some ash timber for round the hatchesIt was supported, it was when I removed the rotten left spar, some joker had screwed it to the glass and i missed the screws now running my own thread in self builds,
