Day run and indicator lamps defect
rdr
Hymer 584
Have 584 2018, the front near side daylight running and indicator lamps have gone defective, both led strip. Fuses checked ok as are all other lamps. Anyone have experience who can assist please. Many thanks in anticipation
Common problem poor quality wires in the headlamp loom.
If you contact TheBig1 he will make you a couple of new harnesses a lot cheaper than anyone else he already has the pattern and made me one as a trial run.😊👍
Let me know when you are back Alan so I can post yours
Yes I can make you up a pair cheaper than Hymer or the other place that sell them. You can repair the faults, but I guarantee that they will break again because of the extremely cheap wires used. The insulation cracks, they then corrode and snap inside the sleeving. My version uses the same plugs, but I upgrade the thickness of the wires and better quality. I then reinforce the flex points on the harness that are also a failure point. It is all protected by woven loom sleeving
By all means give me a shout if you need some. Upon order, I get in the plugs needed and make them up and send out tracked posting within a few days
They sure are crap, I would have had a couple off you if the van wasn't going later in the year. I've just replaced 4 wires in one of my looms. It's always the 4 wires between the main loom plug & the ballast unit that go, a bit strange that the others don't.
Please define "defective".
Not working at all.
Some LEDs work while others don't.
Flickering.
Not working at all, not even a flicker from both drl or indicator, vehicle sensor system detects problem and the rear (working) indicator races
Hi Thebig1 can u make me up lighting harness please for Hymer, defective front drl and indicator.
Dessie
Dessie
I have sent you a PM with details. Envelope top right of your screen
Solution
Dessie
Hi, have now removed defective n/s harness and working o/s one which did light the daylight driving lamp and indicator lamps on the n/s which had not been operating, so wiring is the problem.
would like to retain the good loom as a spare & have you do both new ones please. Both seem identical so is there any need to send both ?, in your previous comm’s you state you use the same plugs then later you indicate you have to get the necessary plugs, a little confused.
state preferred payment options please.
many thanks Dessie
many thanks Dessie
Hi Dessie, the looms are the same left and right, so I only need to examine one. I use brand new identical plugs, which I have to order in. The payment details and address are in the private message I sent you. Envelope at the top of this page.
I know of 2 variants of the looms, that's why I ask to see one. Good idea to retain the working one as a spare, but hopefully with the upgraded version, you wont need it.
You are welcome to email me if it's easier thebig1 at ntlworld dot com
  • Nice One!
Reactions: f6c
Might I suggest you change the @ for an AT to stop the spam bots picking up your address.
Done that but your reply still has it in
