- May 25, 2016
- 25
- 26
- Burstner Lyseo 690G
- 2015 PVC, now from 2020 Coachbuilt
I have a cheapo dashcam with rear camera which works well and was planning to put it on my M/H. However it was a car dashcam so the rear cable length is about 5 metres (micro USB plug to 5 pin connector to rear camera). Having researched, they all seem to be about 5-6 metres because of voltage drop if any longer. A couple of manufacturers said that 5-6 metres is usual although 7 metres is possible.
On my 7m M/H I reckon that I need at least an 8 metre cable if going underneath, or about 11 metres if going inside (which is less hassle).
So, the question: has anyone put one of the little rear cameras on a longish M/H to feed a standard cheapo dashcam at the front, and if so what was the cable run, does the rear camera still transmit a reasonable picture, and what dashcam model and/or extension cable was involved? If necessary I'll ditch the cheap one and invest in something better but only if I know it will work! (I am a bit puzzled because I put a twin rear/reverse camera on a previous M/H with a 12.5m cable length and that was no problem!)
