Dashboard speedometer fixed vs Hud
Dogeared
431
451
Blackburn
Eldiss autoquest 155
Since 2011
Visability on the Speedo on our boxer Autoquest is poor to say the least, particulary km. Is there a decent dashboard one that anyone can recommend, or a decent hud that can be visible in sunlight. Off to France and Spain in a few weeks and would prefer not to be straining to check that I am within the speed limits.
OldAgeTravellers
997
844
Siran, Languedoc, France
Since 1970
I use a HUD which the previous owner fitted so he didn't have to replace the speedo at great expense when he imported the van into the UK which I have now imported into France??
It is fantastic as you never have to look away from the road, one button to change from KPH to MPH. It is plugged into the OBD computer socket and is very accurate compared to the GPS.
As we live in the South of France the skies are always bright so it was difficult to see so I put some tinted film about 150mm across the windscreen with an extra bit just where the image is. I can now see the speed regardless of sun and it also saves a lot of eye strain. The blue strip in the picture below is the MCC banner then you can see the grey below with the extra bit below with a zero in red which is the HUD image it also has a strip of lights below the speed to show the revs but I didn't have the engine running so they don't show. I left the silver screens on so there is more contract without a distracting view outside.
There is no makers name except www.hud-e.com but if they still make it I can thoroughly recommend this particular one.
A friend has the extra speedo on the top of the dash and having seen men says there is no comparison
But I have only used the one I have got. However if you have a Bluetooth plug in dongle for the OBD port then I think that the Torque app for the phone has a HUD option which may be a way of trying it but judging from mine it needs to be very bright to work in daylight.
Good lick.
Steve
Two on Tour
5,990
17,690
Elddis Autoquest 175
Since 2010
I fitted a cheap GPS operated HUD to a imported EuraMobil left hooker we had a few years ago and it worked well and for the same reason without having to change the speedo.
I thought about using one on our present motorhome for KPH while abroad but I'm put off a bit by having the reflective patch that's needed to get a clear readout stuck on the windscreen which does not look nice from outside the vehicle.
Streetwise do one that has good reviews or about £45 which I was tempted to go for. http://www.streetwizeaccessories.co...ries/Recording-Cameras/Head-Up-Display-SWHUD1
There are plenty of reviews of HUD's on YouTube if you want to make a judgement on them.
OldAgeTravellers
997
844
Since 1970
The grey tinted foil Les not off putting at all, as I said it is actually better with it and you can hardly see it from outside. Which I took the photo with the silver screen on so as to give some contrast.
I actually have a letter to the original owner saying that they accept the HUD as an alternative to the speedo when he UK registered it.
Steve
Two on Tour
5,990
17,690
Since 2010
On the streetwise site it says it's a clear film?
Sort of clear. It's see through but silvery to reflect back the image of the hud unit that projected on the film that's stuck to the windscreen.
It's less obtrusive looking out from the inside as you are looking from a darker interior to a lighter outside. When looking from the outside in it's the brighter light level that reflects back at you from the patch due to the lower light level of the interior of the vehicle.
Here's a photo of our old EuraMobil we had. You can see the patch on the lower right side of the windscreen, but from the inside it was barely visible.
I'm not rubbishing the HUD displays as I think there a great bit of kit but what puts me off a bit is the patch as viewed from the outside and the fact that the patch is advertising to a potential thief what you have.
Aug 18, 2014
18,363
80,374
Lorca,Murcia,Spain
Transit PVC
6 years since restarting
Good lick.
Steve
Is this compatible with the CT then ? Anything here inside wiper arc is an instant failure.
I had a sunstrip 10cm (4") wide at top of screen that touched wiper arc by a few mm . failed on the spot. Only time the wipers get checked .:D
Sorry, don't agree, this is what you see from the outside.
Instant fail here.
Jul 5, 2013
9,925
10,474
Tunbridge Wells
Since 2013
Not sure what you mean by accurate but if it is plugged into the OBD port then it will show exactly the same reading as the speedo. But the Speedo is rarely accurate. It is allowed to show up to 10% to fast, but is not allowed to read slow at all. The makers therefore usually have to make it read fast because it just counts revolutions of the wheel rather than distance travelled. The actual distance travelled per revolution will depend upon the radius of the tyre at the point it is in contact with the road. That will vary considerably depending upon tyre size, make, pressure and wear as well as load on the tyre.
The sat nav will be more accurate, especially at a steady speed on a fairly straight and level road.
The Nomad
1,053
1,059
Wandering in Europe
Overcab
Many years
You can just Download any of the free GPS driven speedo apps to your mobile phone and just use that, with your phone in a cradle or holder on the dash board or in corner of windscreen.
Aug 6, 2013
10,988
14,017
Kendal, Cumbria
since 1999
Pressure and load have no bearing on speedo accuracy. The whole tread has to roll along the road for each revolution of the wheel. Tread length varies little due to pressure and not at all due to load (think tracked vehicle when visualising the tread rolling).
Jun 17, 2012
2,692
8,214
North Essex
Autotrail Delaware
>8 but <9
Standard Garmin sat-nav, units set to KPH, never look at speedo, accurate speed displayed and accurate change of maximum speed limits even in France.
Mattyjwr
3,303
10,009
Beds
Panel van
Years
I have a HUD app on my mobile phone which displays the speed in KM or MPH. I position the phone so that the display is easy to see without restricting the road view. I also have a Chinese sat-nav that displays the speed and warns me if I am going over the local speed limit.
OldAgeTravellers
997
844
Since 1970
The foil I used is the standard dark tinting stuff that boy racers use to darken their side windows not the silver stuff you have shown, you can hardly se it from outside, I will try to take a photo tomorrow when it is light and my HUD projects right to the top of the screen just above eye level so there is little refocusing of the eyes not like looking down to the GPS.
And as I said before almost spot on with the GPS, it may well have a GPS inside it as well and only uses the computer connection to get the revs.
I certainly wouldn't be without it and the dark foil was no problem for the CT and I have to have the stricter heavyweight CT.
Steve
Jul 5, 2013
9,925
10,474
Tunbridge Wells
Since 2013
A
Isn't it illegal in the UK to use dark tints on the windscreen or front side windows in all vehicles?
Aug 18, 2014
18,363
80,374
Lorca,Murcia,Spain
Transit PVC
No. UK is one of the few countries that allow tinting of the windscreen , but only to a certain light %, & also forward of the B pillars ( side windows)
Apr 13, 2012
4,924
16,048
Mobilvetta Euroyacht
1996, then break 'til 2011
I have learned to 'know' what speed I'm driving without looking at the speedo........I know if I'm speeding - I think most do
I drove across France last year without a speedo (cable broken), wondered if I'd picked up any tickets
On the way back I used the HUD on my phone - just placed it where the speedo was
It turned out my speed without a speedo was just a bit less than shown on the HUD - no speeding tickets(y)
Steve N Tracy
948
4,023
Southampton
4 Years
The ODB port should give a exact reading of the road speed , the 10 percent inaccuracy is built into the speedo head.
SMB
Apr 26, 2013
1,183
1,147
Spain
Coachbuild
Fulltiming since February 2013
Bought one of these, I can use my spare phone as a speedo using a HUD app. Haven't tried it properly yet as my copilot satnav app isn't HUD-enabled yet but other apps work ok though I haven't tried it whilst moving or at night yet!
Amazon product
Apr 21, 2008
441
721
bedford
speedglow app on iPhone and android. I have a mag mount above speedo and it is so easy to see, no taking your eyes off the road
