Very neat and tidy!Although have a C class, our blinds stop our dashcam being left mounted on the windscreen with the blinds closed, so I mounted ours on a sticky backed mount on top of the dash, fed the the power through under the glovebox and then hardwired it in via the fuse box.
The dashcam stays in situ when the blinds are closed.
Do the recordings come out upside down, or does the camera rotate the image for you?Although have a C class, our blinds stop our dashcam being left mounted on the windscreen with the blinds closed, so I mounted ours on a sticky backed mount on top of the dash, fed the the power through under the glovebox and then hardwired it in via the fuse box.
You can rotate the screen 180 degrees in the menu.Do the recordings come out upside down, or does the camera rotate the image for you?
On the whole nothing to speak of, unless it's bits of road like coming up to big roundabouts with the 100 yards of raised lines across the road to wake you up, oh and of course Belgium roads that rattle your teeth out.Do you get vibrations off the dash?
+1 with nextbase you can turn the screen upside down (sure you can with other makes)Although we have a C class, our blinds stop our dashcam being left mounted on the windscreen with the blinds closed, so I mounted ours on a sticky backed mount on top of the dash, fed the the power through under the glovebox and then hardwired it in via the fuse box.
I have a Ram mount for my phone, using Google maps. Not cheap but a very decent bit of kit.We use silver screens so rarely use the internal blinds. However in case the needs arises I did a minor alteration to a suction cup mount for the dashcam which is easy to remove and replace when needed. The mount is from Ram and does not fall off like cheaper versions over time.
Not the best pic,
