Ros leicester
- May 9, 2021
- 1
- 0
- Autotrail Apache
Anyone know a dash cam that will fit between the windscreen and the blinds? Bought one mainly for security when parked but can't close blinds!
I try to do that but most need the card re-formatting regularly. Incidentally if anyone knows of a camera / card combination that records long-term without the need for re-formatting I'd be very interested.Personally I prefer the low profile devices. They tend to use an adhesive patch to stick to the screen rather than a suction cup. And I don't care about the billions of features and things like screen size or fancy apps. I try to put them out of my sight lines while driving and have the screen turn off after start-up. I just want it to be reliable and for it to be there if anything happens. Fit and hopefully forget.
The last one I had was running for about 25k miles over 4 years. I only pulled footage off it once and it was working fine. It was a basic one by Aukey. Did have a SanDisk SD card in, maybe that makes a difference? There are SD cards that are especially for continuous use now that cost a few quid more.I try to do that but most need the card re-formatting regularly. Incidentally if anyone knows of a camera / card combination that records long-term without the need for re-formatting I'd be very interested.
Thanks. I probably need to do some research as it was a few years ago I last looked.The last one I had was running for about 25k miles over 4 years. I only pulled footage off it once and it was working fine. It was a basic one by Aukey. Did have a SanDisk SD card in, maybe that makes a difference? There are SD cards that are especially for continuous use now that cost a few quid more.
What make and speed class sd card do you use with the mobius?We use a mobius actioncam (designed originally for remote control airoplanes) with a detached/extended lens stuck to the screen through the gap at the top of the blinds. The main box then doesn't get in the way of the blind if that makes sense. Not for everyone as there's no screen so setup can take a while: https://www.mobius-actioncam.com/ but have used these on various MHs and cars for family members.
Yes I remember I did the capacitor upgrade as the original battery cooked in the sunRichard n Ann I'm sure it's a class 10, it's in the MH right now but I'll try and check for sure later. I know I bought the fastest I could buy at the time. I've had ours in the van for a good 5 years now without any issues. I have a few spare that I've tried new firmware with but they're not as reliable :-( That's why I've bought a cheap £20 dashcam from Amazon for the car until I get time to fix them, though I may give up as they're getting harder to keep going and you can buy cheap ones now-a-days.
The battery can go as well, there is a capacitor battery available but I've not had a lpt of luck with them.
