Dab Aerial (1 Viewer)
Nov 2, 2022
250
1,067
Cumbria, UK
Hobby Optima T65 de
Too long
I have just fitted a Kenwood DAB unit but I have been searching for a company called DABonwheels who I have previously used for info/recommendations and purchases. They seem to have disappeared and the website seems to have been taken over by someone dealing in cars. Anyone know anything about their whereabouts now please?
Peppadog
617
801
Nr Bath
Sunlight C600 pvc
Since the late 70's
No, but if you are looking for a DAB ariel as per your thread title, Halfords have them for £20.
Gerry77
Nov 2, 2022
250
1,067
Cumbria, UK
Hobby Optima T65 de
Too long
Thanks saw those but they are passive aerials and I understood that active aerials gave better performance. So was really looking for an active one.
ambulancekidd
Sep 23, 2014
10,075
28,086
Ayrshire Scotland
Swift Kon-Tiki 640
Since 1964 Gosh that makes me feel old.
If you're motorhome happens to have a Status type TV aerial, hook up to that for reception. I'd tried all sorts with limited success until I fitted a brand new Status aerial with a DAB diplexer which can come with the aerial, reception....Flawless.
Peppadog
617
801
Nr Bath
Sunlight C600 pvc
Since the late 70's
Just searching google might help. I just installed a new Sony double din unit and bought a Halfords ariel. It turned out I didn’t need it as I found both standard and dab leads behind the dash of my 2019/20 ducato so took it back. Lucky I hadn’t opened the pack! It seems to work well
Gerry77
Nov 2, 2022
250
1,067
Cumbria, UK
Hobby Optima T65 de
Too long
Lucky you. Mine is a tad older @ 2012 so no dab aerial.
And I don’t have a Status either.
cliffanger
4,697
32,822
Saltford
Hymer A class
Since 2013
You’ve got the same van as us I think, and Cliff fitted a a stubby aerial to the front panel of the van.
He made an aluminium reflector plate to make the aerial work.
The cable is fed through the cup holder and into the dash.
We tried a few aerials before doing this and none worked. This works a treat, and we never lose the signal. 👍
If you need any info, just ask.
Upvote 1
Gerry77
Nov 2, 2022
250
1,067
Cumbria, UK
Hobby Optima T65 de
Too long
What a great idea. Which aerial did you use and I presume the aluminium plate is bent and fitted under the panel ?
cliffanger
4,697
32,822
Saltford
Hymer A class
Since 2013
We bought it from Amazon.
Techno Andy told us which one he had used, and we bought the same one.
Eightwood DAB Car Aerial DAB Antenna Splitter Amplifier SMA/SMB to DIN Connector Universal Roof Car DAB FM Antenna 5M 16.4ft Cable Compatible for FM Radio DAB Car Radio Blaupunkt Pioneer Alpine JVC https://amzn.eu/d/cpXHkaH
Remove cup holder on passenger side (just pull it out). There’s an air duct that you can drill into from under the bonnet, and then feed the cables through attached to a thin piece of wire.
The aluminium plate followed the contour of the panel. It was about a 2 or 3mm thick plate.
If you need any more info just PM me and I’ll give you Cliff’s number.
It works really well, and never loses signal. We tried others before this and it was a total nightmare.
