But I'm really surprised a 2015, 3-litre Ducato pvc with comfortmatic gearbox doesn't have a cruise as standard?
Not the case on our 2013 3.0 Comfortmatic.Most importantly, the after-market could be paused by operating the switch but the factory-fit requires a dab on the brake pedal.
n.
Had a 2008 X250, a 2014 X250 and a 2017 X290 all the same.Not the case on our 2013 3.0 Comfortmatic.
There is a button on the end of the cruise control stalk that you press to knock cruise control off. Press it again and it resumes the previous set speed.
You both had me wondering there, so I've checked the Fiat manual. It lists about 6 ways of disengaging the cruise control including turning the engine off, but it doesn't mention pressing that button, which on mine is labelled "Res", presumably for resume. I've always thought it was an obvious function for that button. One of life's little mysteries!That's interesting, folks. That button on mine resumes the set speed but doesn't pause it (on a 2010 X250). Perhaps it doesn't work, and if that's the case I apologise for clouding the issue.
yep and mineNot the case on our 2013 3.0 Comfortmatic.
Yes very do-able, £418.86 Inc vat less 5% funster discount(please tell us you are a Munster at time of booking).I believe it will be, but @dave newell lvs is your man.
Is that a spilling orrer? Should that be Monster?Yes very do-able, £418.86 Inc vat less 5% funster discount(please tell us you are a Munster at time of booking).
D.
