Cruise Control Stalk (1 Viewer)
Aug 4, 2016
608
1,374
Yorkshire
Vantage Neo
Since 2003
Anyone changed the stalk? Is it possible without removing the steering wheel/airbag? Mine is kaput I think, Error P0579
I've posted on the Fiat forum but so far it's fallen on deaf ears.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
I'm just waiting for one to be fitted under warranty.
It has a mind of it's own, sometimes works by the book, sometimes, press Up and it tries to take off.
Sorry I can help on fitting it thought they said it was a quick job.
May 19, 2014
95
69
Plymouth
Fleurette Migrateur
Hi I had my cruise control fitted ie a new one, as I fell over in the cab trying to close the front blinds and head butted the stock, not advisable but it was expensive the most expensive head but I ever done, I had it repaired at a dealers
All the best
Whiskeymac
csd4t
Aug 4, 2016
608
1,374
Yorkshire
Vantage Neo
Since 2003
Mines the same but I believe that most of the problems are just dodgy contacts. If it comes off without the steering wheel then I'll have a go, but I don't want to start messing around with the wheel/airbag connectors:oops:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Finally got it sorted today.
The whole stalk cluster has been changed, both sides, all one unit they said. I did not see the job so no wiser as to how difficult it is.
Feb 22, 2016
3,608
10,669
York
Bailey 620 Approach
Since 2015
I hate to imagine the cost, hilldweller!
Feb 22, 2016
3,608
10,669
York
Bailey 620 Approach
Since 2015
Phew! Ours is now outside the 3 year “warranty”. I put warranty in quotes as when push came to shove, almost nothing was covered. If I were buying again, would not be suckered into an extended 3 year warranty.
Anyway, glad you got it sorted under warranty.
Tribbtravs
Banned
Oct 13, 2017
108
379
How did you get the stalk off without removing the steering wheel ? Do you by chance have any pics of how you did it?
Our cruise control is just accelerating and have to turn off.
csd4t
Aug 4, 2016
608
1,374
Yorkshire
Vantage Neo
Since 2003
Test was a failure but I have tried again to adjust/clean the terminals don't have any pics but remove fuse cover, remove bottom cover( two screws) remove bottom half of steering column cover (mine has four 3mm hex screws) then the stalk is held with two plastic tabs, I used two small screwdrivers to hold them off then it just pulls out remember to remove the connector first.
Tribbtravs
Banned
Oct 13, 2017
108
379
Many thanks for your reply. I will give it a go the weekend.
Cheers Tribby
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
All the best
Whiskeymac
Too much of your namesake?
Tribbtravs
Banned
Oct 13, 2017
108
379
I have got this far but can't work out how to get the stalk off. It looks like I need to get at the screw that needs the steering wheel off to get a screwdriver on. Any idea's. Cheers Tribby
csd4t
Aug 4, 2016
608
1,374
Yorkshire
Vantage Neo
Since 2003
At positions 12oclock and 3oclock as you look at your picture there are plastic tabs. Hold both of these away from the body and it simply pulls out.
Tribbtravs
Banned
Oct 13, 2017
108
379
Many thanks for your help csd4t. Got it off and apart and have cleaned the connectors. All back together but can't test it now until the weekend. Cheers Tribby
csd4t
Aug 4, 2016
608
1,374
Yorkshire
Vantage Neo
Since 2003
Not sure if mine is working yet but at least I can remove it now
Lenny HB
53,301
149,448
On the coast in West Sussex
Hymer B678 DL
All the best
Whiskeymac
I can't work out how you could do that as the stalk is under the steering wheel unless you are under 2' tall.:ROFLMAO:
Tribbtravs
Banned
Oct 13, 2017
108
379
Tried mine over the weekend and it worked perfectly. I got rid of the grease with contact cleaner. I know it might rub off the copper track eventually without it but know how to get at it now to fix it again. Cheers again csd4t.
csd4t
Aug 4, 2016
608
1,374
Yorkshire
Vantage Neo
Since 2003
Happy to report all working again, couple of days at Leyburn with the dog to celebrate
