Cracked Roof (1 Viewer)
Lord Mac
190
232
Devon
Autotrail
I'm a newbie
I have found a crack in my roof at the over cab sleeping area, I must have hit a branch. I have repaired the roof with fibreglass but my problem is that I have had water ingress. There is a large damp stain on the inside over the bed. What can I do? Do I hope it dries or should I put a heater up near the area?
Thank you in anticipation.
Badknee
7,395
408,984
notloB
Vantage Neo
Living the dream.
Heater and a dehumidifier, heat causes moisture, dehum gets rid of said moisture. Good luck I hope it's not too bad.:)
RS_rob
1,010
669
Turnford
Fibre glass will be your problem its not flexible enough you will need to remove it & fill with something that has some flexibility in it.
Lord Mac
Lord Mac
190
232
Devon
Autotrail
I'm a newbie
Thank you for the replies. What do I use instead of fibre glass?
MikeD
3,936
3,697
London
IH PVC
Not sure why it would not be strong enough but I am pretty confident the front over cab part of mine is made of glass fibre.
I did crack it and had it repaired but I have no idea of how they did it.
Badknee
7,395
408,984
notloB
Vantage Neo
Living the dream.
Suggested on here in the past that you grind the edges to make a "V" and fill it with sealant. Sicoflex or some such stuff? Perhaps if you do a search on here for sealants?
Wickolad
490
542
Wickersley
I have seen a couple of you tube videos regarding Gel Coat repairs to cracked panels. The Gel Coat product is available in various colours including the obvious White. As mentioned above, a V grove is ground along the crack line to facilitate good penetration of the filler coat. The kits are readily available from East Coast fibreglass supplies, ÂŁ14.95
It depends of course what your roof is made of.
23,821
71,977
Do you know what the roof is made of ?
If plastic, then repair with plastic ( fibreglass will not make a good repair on plastic at all )
As mentioned above, sikoflex is very good for such things, but there are several products available to repair all sorts of plastics, even HDP and he like..
Chances are the roof ( if plastic ) will either be polycarb or acrylic .. Both types repair really well
