Captain Lloyd
I can’t find anywhere the meaning of this code
Thanks I have got it working now after a few resets, I just would like to know what the fault meant incase there is anything that needs attention.Try hooking up to electric it is not showing hook up or battery so needs a power input, not a flat battery as you have the display.
Thank you very muchIts to do with the power source you need to allocate battery or EHU and then switch on otherwise this code appears ( mine does the same!) Everything will work but needs a dedicated power input! Just as you did switch off and reset
