Correct Tyres Pressures?
Nov 15, 2017
59
4
Hi, I would be very interested to know what sort of Tyres Pressures you guys run at in your 3500kg Motorhomes? Even Quickfit who just fitted some new Michelin Aquilas Camping Tyres (215/70 R15 ) were confused. They contacted Michelin and they couldn't come up with anything definite. In the end they put 4.25bar (62psi) in the front and 5.5bar (80psi) in the rear. We're off to Spain in a few weeks and will be travelling at max load, so I wondered if anybody had any suggestions or recommendations or indeed experiences that would be helpful. Our Motorhome is a 2009 Swift Bolero Multijet Engine. 3500kgs. Fiat Ducato based.
funflair
15,241
20,145
Guisborough
MORELO palace
since 2012
I believe all Michelin are ever going to say for the rear axle is 80psi, other than that you would need axle weights to make any sort of guess.
Martin
Sep 28, 2015
1,496
1,577
Kingston upon Hull
Hymer B544
2011 on
You must get it weighed in ready to set off condition with all people on board, so you know the front and rear axle weights. You won’t get any sense out of Michelin regarding pressures. Continental do a technical data book, available on line, that gives the correct pressures according to tyre size/index.
I was able to lower my pressures considerably after weighing and checking the data book.
We now run at 4 bar rear and 3.25 bar front, making a real difference to comfort and noise. Don’t take any notice of my pressures though, do your own calculations after weighing.
http://blobs.continental-tires.com/...998ef8b3/download-technical-databook-data.pdf
funflair
15,241
20,145
Guisborough
MORELO palace
since 2012
They will be 109 load rating which will give you 2060kg on the axle at maximum pressure.
If it was my van I would drop it pro rata to the actual weight.
Martin
Jul 29, 2013
6,909
9,190
Salisbury
Hymer B678DL A class
since 2011
We have a Hymer Exsis 4250kg when fully loaded and towing car trailer run at 4.5 front and 5.5 rear seems to work for us and certainly not harsh ride, however we are close to our Limits.
40,348
38,078
My 7500kg RV ran at 80psi in all 6 tyres.
My feeling is the same pressure in something half the weight and tyres 3/4 the size is going to be a bit hard and bumpy.
Jan 31, 2016
1,108
583
Halifax
A Class Rapido 9097F
June 2016
We run Avon AV9
We run on fully loaded figures even thou we not always fully loaded just easier
Front weight 1850 = 58psi 4bar
Rear weight 2000 = 64psi 4.4ba
215/70R15 109/107R
Two on Tour
5,957
17,565
Elddis Autoquest 175
Since 2010
Continental VancoCamper tyres have 69 psi on the side wall but it is not marked as being the maximum psi.
If this is the rated maximum psi and your running the 80 psi that's recommended for rear axle weights around the 2000Kg mark, then how are insurance companies going to react to the tyres being over the manufactures stated limit ?
soreeyes
351
136
Sunlight T69L 2017
im a newbie
Without actually checking actual weights from my motorhome I doubt you would exceed 1600 kg on the front so 62 psi and 2000 kg on the rear at 80 psi would be not far out ?
My Vanco camper 16 inch are quoted at 79 psi on the plate interest not looked at max inflation on the side of tyre though .
Lenny HB
32,272
60,484
On the coast in West Sussex
Hymer B678 Dynamic Line
The max pressure shownon a tyre is only valid in the USA, don't ask why haven't a clue but it's true.
Jul 26, 2017
436
923
Macclesfield
Elddis Accordo 125
Since 2016
70 front 80 rear. Roughly in line with the 'van's manufacturer's spec but checked with other online resources. There seems to be a lot of conflicting advice about.
I wrote the pressures on the inside of the wheel arches with a permanent marker to remind myself.
Sep 28, 2015
1,496
1,577
Kingston upon Hull
Hymer B544
2011 on
Looks like it’s taken straight from Michelin with no variation in pressure regardless of weight/load applied.
Tanya_and_Mick
1,461
46,607
Algorfa, Spain
Globecar 640DK
Are there any insurance implications, with running at pressures not defined by the manufacturer?
Tanya_and_Mick
1,461
46,607
Algorfa, Spain
Globecar 640DK
Presumably only if the tyre pressures were found to be a directly contributable factor in an insured loss. Seems unlikely for any reasonable pressures.
mmmm that could be fun, considering they are the only things in contact with the road - how would you prove they were not, if the insurance company said they were - interesting????
