Coordinated wrong in acsi book? (2 Viewers)
Feb 19, 2015
1,776
1,249
Norfolk
Globecar Campscout 2013
Since 2016
Posting again as the last effort screwed up the titie - apologies! F
urther to my grouse about satnav (Garmin Nuvi) cutting out and going wrong right at the end we are now looking closely at the coordinates. They simply seem to be wrong for where we are. Today it tried to take us onto a canal path. Someone watching offered to drive us to the campsite which was about two km away. These coordinates all come from the acsi camping book. Has anyone else noticed they are wrong? We just tested it now at the campsite and where we are is different coordinates to the book. This is the third time wrong.
Feb 16, 2013
19,731
52,008
uttoxeter
ambulance conversion
50 years
As has been posted before, there are 3 different ways of putting in coordinates SCSI caught us out as well, nearly got us in the sea.
Oct 5, 2012
4,283
9,569
Ayrshire
Carado T132
5 years, feel free to ask me about the Carado!!
Not meaning to be rude but are you using the correct easting and Westing settings on the sat nav. On the Nuvi you need to set E or W for some coordinates depending where you are!
Feb 22, 2008
12,263
45,047
Norfolk
Nearly Tugging
Since 2004
as above must use the correct co ordinate format, 3 choices on Garmin, and when input you get the option to view map which will confirm if you have the correct location.
Jac Sprat
Feb 19, 2015
1,776
1,249
Norfolk
Since 2016
This must be what we are doing wrong as it's happening so often
Could you kindly explain further about the the three different options on Garmin as we're only seeing one
Just 'easting and northing' coordinates . Very much appreciated .
Feb 16, 2013
19,731
52,008
uttoxeter
50 years
Just put the one you have in the box and it will convert it to the others
Jac Sprat
Feb 19, 2015
1,776
1,249
Norfolk
Since 2016
This is the page in the acsi book
And the one under is what sat nav says we are at.
Oct 5, 2012
4,283
9,569
Ayrshire
Carado T132
When you go to the coordinates menu there is a little spanner on the top left of the screen, here you can set the coordinate types. Just experiment, most camping references use one of the 3 numbered sequences on the menu choices. also check you have E &W set correctly when you input the coordinates from your reference in the main input menu they are at the top of the screen.
Mar 11, 2014
934
1,331
Lincs
PVC
Since 2010
Looking at that the book is using one method and your Garmin is using another.
Are you able to go into the garmin menu and change the type of co-ords? I think our Garmin gives the option of inputting in 3 different ways.
ETA Campa cola faster than me!
Feb 16, 2013
19,731
52,008
uttoxeter
50 years
Yes both right just different way, you ha be to know which you are working with, alltheaires and France passion use different ones,you have to be really carefull
lunarman
2,156
2,451
South Glos
since 1994
@Jac Sprat I have put the co-ordinates into both my sat nav (chinese cheapie) and google maps they both arrive at the same place. A sharp left hand bend in the rue de plaisance. street view shows the gates to the campsite. So the coord look correct to me.
lunarman
2,156
2,451
South Glos
since 1994
Replied before I saw your pictures. You are using the wrong input format.
DBK
18,021
48,079
Plympton, Devon
PVC, Murvi Morocco
I hope this doesn't confuse things but the pictures you have posted show exactly where you are going wrong.
The ACSI coords are given in the format degrees, minutes and seconds. Your satnav is set to degree and minutes only. It is possible to convert one to the other with a website but it really shouldn't be necessary, you just need to set your satnav to accept coords in the correct format.
You need to go into settings and find the format which should be listed as ddd mm ss (if it is anything like my Garmin). Yours is currently set it to the option ddd mm.mmm
Ignore the next bit if you want: :)
There is a link between the two formats and this may explain why you are getting close to a site but not close enough for the proverbial cigar. If a site was listed as being at 20° 15' 30" you have been entering it as 20° 15.30 but it should have been entered as 20° 15.50 because 30 seconds is half a minute, there being 60 seconds to the minute, so the correct number was 0.5 as a decimal not 0.3.
Lee Fryer
566
5,155
Eastleigh
Coach built CI Carioca 15
Since June 2012
Sat nav entree is different to book. IE ' should be behind 56 & 22 '' Should be behind 9 & 59
Lee
Oct 5, 2012
4,283
9,569
Ayrshire
Carado T132
andy63
4,672
15,017
south shields
None
since 1990
Don't want to confuse but ill add some photos of my gamin. .may help you get to the right cordite format..
After choosing to enter coordinates you will get something like this
Choose the menu item..In my case the three little bars..
And you will get this ..
Choose format and you will get your choice of formats.
Pick the one you need to use and save it...
Hope that helps
Andy
Reactions: DBK
Oct 5, 2012
4,283
9,569
Ayrshire
Carado T132
Hope that helps
Andy
In the last pic he needs the 3rd option (y)
Gellyneck
9,212
18,187
Scotland
More than toes wet now!
