I am looking at fitting a solar panels and am a bit confused.
It's stated that you should connect the battery first then panels. Therefore the panels should be disconnected before the battery. What is the effect on the controller if this is instruction isn't followed?
It's common to see threads on here where a fuse is fitted between the controller and battery. What is the reason for this? It seems contradictory, but I may be missing something obvious. If the fuse blows you're in effect disconnecting the battery first.
