Control panel
Adam b
South queensferry
Auto cruise carrera4
Trying to find out what this means on my control panel, the van isn’t on hook up & the solar panel is disconnected ?
Don’t know your control panel but if that was on mine it would mean I’m using 1.4 amps on lights etc, mine says 0.6 at the moment.
0.2 of that of that is the control panel and the other 0.4 is two LED lights we have on.
That’s what I thought but I have switched everything off.
Sometimes, the current isn't measured by a proper shunt and it needs calibrating to read an actual zero. Not sure if this applies in your case. Another alternative is that you haven't quite managed to switch everything off.
If the current is preceded by a '+' sign it indicates a charge. A '-' sign indicates a discharge.
So where is the charge coming from, solar panel is disconnected & it’s not on hook up.
Possibly a miscalibrated meter that needs re-zeroing.
Ok thanks, I will check it again & try to find out how to get it recalibrated.
Have you turned of the fridge and heater control circuit boards... Not that you can turn them off without totally isolating the battery.
Every little drain adds up to a bigger drain.
I’m pretty sure everything is off , but as tonyidle says + sign suggests a charge
