Compressor Fridge not working (1 Viewer)
Nads
5
England
LWB
4 years
Hi I wonder if anyone else has any problems and can offer some advice. Firstly I apologise if my descriptions aren't great, one I'm a girl and two as the van hasn't been used over the winter I can't remember exactly the sequence of what happened.
I have a Waeco CR80 Fridge, It's been playing up for ages and now is not cooling at all.
when it started it would randomly stop cooling and defrost. I'd hear it kick in then hear a fan type noise, but the the normal noise which i presume would be the compressor. I'd turn the fridge to colder setting and the what i think is the compressor would kick in, then almost straight to the fan noise.
Then after a while it would work fine again and then the problem would start again.
Now the light is on but no-one is at home!!!
I've removed it and will test the electrics with a friend but any hint or tips or if anyone has had a simular problem I'd really love to hear from you.
Many thanks
TheBig1
17,630
43,266
from the description I would suggest the thermostat has failed
3
34127
Try checking the voltage at the fridge.
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
is it running from your leisure batteries or do you have the power pack and connected to ehu my first thought would be low power if on batteries if on hook up then check the power pack is delivering should have 240 in 12 out to fridge
Aug 26, 2008
4,762
24,943
B&NES
Van Conversion
since 2007
Even if the van is not used over the winter it is a good idea to run the compressor fridge occasionally. On EHU if the leisure battery voltage is low.
