Compas Merit 460 1996 Peugeot Boxer 2500cc Engine (1 Viewer)
Alan Mayell
Hello,
Never done this before so please excuse any no protocol. I am in the process of purchasing a Peugeot Boxer cabed motorhome. The third gear ''cluncks'' as the sycro appears to have gone. Having problems getting prices to replace locally. I have asked for the clutch to be checked at the same time. Anybody any ideas??
Minxy
32,623
66,460
E Yorks
Carthago Compactline
It could be that it just needs adjusting rather than replacing ... best to let a garage check it first and do a bit of research on the web too, to see if it IS definitely a replacement job.
Oct 8, 2016
221
224
bognor regis
Burstner Aviano 675G
10 years
We had that engine on our first van, it’s as tough as old boots, but there’s no turbo so its slow uphill. I seem to remember we had a clunky box and occasional funny noises from the clutch which I had replaced. They have to drop the box to get at it so it’s not cheap, in our case it made hardly any difference anyway ! A new clutch cable might be a better step than replacing the clutch. Get some advice from the pros.
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
RS_rob
1,010
669
Turnford
over a Year Yay................
Whats the millage on it ?
Ours is stiff when cold so requires a good warm up & was worse after we had the oil changed but a run down to Cornwall fixed it.
5th gear is the one to watch as it can fail due to lack of lubrication as it is a bolt on item & not actually inside the box, the fix is to overfill the box to 1.75 litres & not to engage it untill fully warmed up then out on a run (in our case anything below 60) drop down to fourth to allow the oil to spash 5th gear & give it some lube.
