Some advice needed from you knowledgeable people.
We have recently upgraded to an Autotrail (Fiat) 2011 with 3lt 6 speed comfortmatic gearbox, with 13000 miles.
We thought we should take her out for a couple of nights to get used to all the new to us controls both mechanically and with habitation. By the way this is our first Automatic.
We drove to within 2 miles of the site ( after about 70 miles with no problems ), and suddenly it jumped out of gear and was stuck in 2nd. The message CHECK TRANSMISSION and warning light came on also CHECK STEERING and warning light. Then a message AVOID CHANGING GEAR TO OFTEN appeared. We crawled into the site,then checked both transmission and power steering levels. Transmission level was halfway between max and min, the power steering was on minimum.
I topped up both reservoirs before we left for home.
All going well on homeward journey until I exited main A road at our home town at roundabout when again it jumped out into 2nd gear then CHECK ENGINE and warning light appeared. Quite frightening and dangerous.
Has anyone had same problems or know the cause.
In the last two weeks I have had a tracker/ alarm fitted if this may have any connection to this problem.
TIA.
TIA.
