Combitronic Eberspacher (1 Viewer)
Mar 3, 2021
16
Essex
Renault Master
I’m a newbie
im looking for reconditioned boiler for my motorhome, it’s 5 reg Peugeot Boxer Autocruise the boiler is as named above and works hot water and heating,off diesel, or does anyone know anything about it, Thanks in advance, Sue
skippy85
Mar 3, 2021
16
Essex
Renault Master
I’m a newbie
Thanks for help ours is not firing up,had a look on the website, I’m now going to take it off to find out which one it is
andy63
4,672
15,026
south shields
None
since 1990
hi, its been a while since I installed a combitronic system in a self build , but if it is anything like the one I had the boiler unit will be an eberspacher hydronic unit..they can be a self contained system or engine plummet as well but more likely self contained... if you have a separate header tank for the primary heating system it won't be an engine plummet version...
if the boiler isn't firing up it could be ant one of a number of things from low voltage to duff glow plug , def dosing pump etc..
you can get service kits for the hydronic heaters, and they are not that difficult to dismantle once you have the unit out..
Andy
skippy85
Mar 3, 2021
16
Essex
Renault Master
I’m a newbie
Hi thankyou for help, we are not good with technical problems, I’m going to take the pump out and replace the glow plug with a new one if I can get hold of one give the unit a
good clean and put back,
