Cold water leaking out
HandM
Hobby T600 FC
Total newbie
Me again! We have fresh water leaking out of what looks like an overflow pipe whenever we use a tap in the sink or bathroom. Half the water pisses out under the van and only a bit comes out of the taps. So we are losing most of our freshwater stock.... it’s the pipe hanging just in front of the spare tyre
Check you`re frost protection valve is closed, it`s next to the boiler
Usually has a red button you pull up, but some models may be different
Sounds like your drain tap from the boiler may be on ..... above that pipe there will be valves/taps
Try turning them ...
