Got my MH taxed from today as been on sorn since Nov ...went ok but for some reason the spedo and temp gauge dont work.Tried the fuses on drivers side r/h below dash but all ok ...any ideas ?
I think that the problem that Crashdata sort out is with the air-bag ECU fault (warning light problems etc)Isn't there an issue with the Citroen's and Fiat's ECU that can be caused by low battery voltage that requires sending the unit off to Crashdata ?
If you've had it Sorn'd, have you kept the cab battery charged up satisfactorily ?
Battery has been charged by solar panel on roof and gave it a good run out ...seems strange that the spedo and temp gauge are not working but fuel gauge etc are ? I know where the fuses are in front of drivers right knee on dash and under bonnet r/hand side but is there any more fuses anywhere ?Isn't there an issue with the Citroen's and Fiat's ECU that can be caused by low battery voltage that requires sending the unit off to Crashdata ?
